Author Topic: New car on Tuesday ....Cited !  (Read 30355 times)
Offline Janner_Sy
  • -Receive: 113
Re: New car on Tuesday ....Cited !
« Reply #150 on: December 14, 2009, 08:25:28 pm »
next lot of logs being put up here now.
« Last Edit: December 14, 2009, 08:27:21 pm by vRSy »
Offline Janner_Sy
  • -Receive: 113
« Reply #151 on: December 14, 2009, 09:00:39 pm »
heres his second run logs very much similar
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #152 on: December 14, 2009, 10:15:03 pm »
same ish profile , up , down , then back up again on throttle angle sensor ......
have you tried logging in a higher gear e.g. 6th ?
have you checked for fault codes?
have you done a throttle body reset?
but my first suggestion....
flash it back to stock and log again to see if you get the correct 99.6% at point of WOT.....
« Last Edit: December 14, 2009, 10:16:55 pm by john_o »
Red ED35 5dr DSG
BLOG | BUILD
Offline Janner_Sy
  • -Receive: 113
« Reply #153 on: December 14, 2009, 10:40:58 pm »
logging in 6th on public roads, prob wouldnt reccomend that. whats 1500rpm in 6th about 35mph @ a guess id say if you pull that through the rev range your in some seriously  high spped, and you aint going to have much road to pull that off.
3rd and 4th gear all the way.
Good advice though to takethe bluefin off and see how it is without that.  Ddefinately worth the try.
But the thing is though, his throttle angle does hit 99% after 3800rpm, which surely means it is working, and does function, but something in his ecu or map is not telling it to open up all the way below that?
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #154 on: December 14, 2009, 11:03:36 pm »
lol wasn't suggesting full run in sixth. Just enough to prove full throttle below 3800.  sounds like its the low power bf map to protect the dsg box maybe? Stock mode is good start. Or take it to a respected vw special list
  You close to Jkm?
Red ED35 5dr DSG
BLOG | BUILD
Offline djhorace
« Reply #155 on: December 15, 2009, 07:38:52 am »
  You close to Jkm?
Nope - About as far away in the UK as you could be from them lol
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #156 on: December 15, 2009, 08:02:46 am »
ah ok  :signLOL:
check for codes then
flash to stock to get the 'default' behaviour for the throttle % and take it from there.....
(with further logging in std mode for N75 and angle delays)
and then try ESP off when logging in BF mode
Dont thrash the car silly until you can ascertain why its not running right (enough to log only)
there are 2 sensors so if you log both they should add to 99.6%
remember you can try this with the engine off
[edited : whilst not related to your issue ,  this post
http://www.golfmkv.com/forums/showthread.php?t=82165
confirms that 99.6% is the value you should be seeing if everything was ok for 'one of the bluefin' maps, this fits with the other tuners maps Ive seen logs for.
It also looks like the signal gets modulated when issues occur.]
« Last Edit: December 15, 2009, 08:46:11 am by john_o »
Red ED35 5dr DSG
BLOG | BUILD
Offline subaru26675
« Reply #157 on: December 15, 2009, 11:34:13 am »
Right, first of all a BIG thanks to you guys for spending the time to plot up the graphs and tables etc, really appreciate your time in looking into my fault and cant thank you lot enough  :notworthy:   I am on nightshift mode just now so sorry if it looks like i am not replying enough to your posts  :ashamed:.
I am just of the phone to the lad in Aberdeen with the VAGCOM and i will not be able to do the standard run until tomorrow. Should i just do the run with the same logging paramaters or is there anything else that needs to be logged ?
The car is in standard form just now and ready to be tested.  Really am a bit depressed just now, the car only being 18 months old, i expected just to plug in the SC map and be away with no problems whatsoever, however on the other hand i am on a steep learning curve on the VAGCOM diagnostics and have met DJHorace through this,  so its not all bad. DJHorace (Allen) has been the most helpful guy i think i have ever met, nothing seems to be a problem for meeting up, he gave up his friday night at the drop of a hat to do some logging on my car and has spent some time making enquiries for me...absolute gent !  :drinking:
« Reply #158 on: December 15, 2009, 12:01:36 pm »
Log the N75 Duty Cycle.
You can log up to 12 with advanced measuring blocks if need be.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #159 on: December 15, 2009, 12:24:06 pm »
tis what forums are for  :happy2:
im not expert btw just a keen forum member.
you are looking to prove your car behaves correctly on the std map :
i.e.  99.6% throttle at WOT from point of run (1500 rpm ?) , boost spool early to peak at 3k rpm ish , N75 duty cycle common profile.
good luck
Red ED35 5dr DSG
BLOG | BUILD
Offline Janner_Sy
  • -Receive: 113
« Reply #160 on: December 15, 2009, 12:30:50 pm »
you need to do those logs on both maps though.
hopefully it performs fine on the standard map, if so then you can give it too superchips to sort out, and you wont hve to replace anything on your car.
anyone know what blocks they are that he needs to log?
« Reply #161 on: December 15, 2009, 12:36:29 pm »
Try here in the VCDS section.
http://www.mk5golfgti.co.uk/forum/index.php?topic=5026.0
Does the OP know it is possible to log on the Bluefin handset?
Offline Janner_Sy
  • -Receive: 113
« Reply #162 on: December 15, 2009, 01:12:25 pm »
cool, didint know that. presuming that is part of the new software on the handset. mine was the old software and couldnt read DTCs
Offline djhorace
« Reply #163 on: December 17, 2009, 03:31:02 pm »
OK - Car was logged just now in mapped and standard mode logging 003 114 and 115 & 003 114 and 230
Throttle seems to be perfect in standard mode . Logs below. Again, if someone can tell me how to post these properly, it would be appreciated
Unmapped
Thursday   17   December   2009   14:47:49
1K0 907 115 T      2.0l R4/4V TFSI     0010
   Group A:   '003            Group B:   '115            Group C:   '230
      Engine Speed   Intake Air Mass   Throttle Drive   Ignition      Engine Speed   Engine Load   Boost Pressure   Boost Pressure      Rail Pressure   Rail Pressure   Rail Pressure
   TIME         Angle Sensor 1   Timing Angle   TIME         (specified)   (actual)   TIME   (specified)   (actual)   Difference
Marker   STAMP    /min    g/s    %    °ATDC   STAMP    /min    %    mbar    mbar   STAMP    bar    bar    bar
   0.01   720   2.19   1.6   -1.5   0.13   760   15   270   1020   0.25   50   50.25   -0.25
   0.38   760   2.19   1.6   -3   0.52   720   15   270   1020   0.64   50   49.76   0.24
   37.89   760   2.44   1.6   -3.8   38.02   760   15   260   1020   38.16   50   50.69   -0.69
   38.28   760   2.44   1.6   -3.8   38.41   760   15   260   1020   38.53   50   50   -0.01
   38.67   760   2.47   1.6   -3.8   38.8   760   14.3   250   1020   38.92   50   50.65   -0.66
   39.05   760   2.39   1.6   -3.8   39.19   760   14.3   250   1020   39.31   50   49.96   0.04
   39.44   760   2.39   1.6   -3.8   39.56   760   14.3   250   1020   39.71   50   50.49   -0.49
   39.83   760   2.33   1.6   -2.3   39.95   760   14.3   260   1020   40.08   50   50.23   -0.24
   40.22   760   2.33   1.6   -2.3   40.34   760   14.3   260   1020   40.47   50   49.88   0.12
   40.6   760   2.39   1.6   -2.3   40.74   760   14.3   250   1020   40.86   50   49.91   0.08
   40.99   760   2.36   1.6   -3.8   41.11   760   14.3   250   1020   41.25   50   50   0
   41.38   760   2.39   1.6   -4.5   41.5   760   14.3   250   1020   41.63   50   50.48   -0.48
   41.77   760   2.39   1.6   -3.8   41.89   760   14.3   250   1020   42.01   50   49.42   0.57
   42.14   760   2.36   1.6   -3.8   42.28   760   14.3   250   1020   42.4   50   50.32   -0.33
   42.53   760   2.36   1.6   -3.8   42.66   760   14.3   250   1020   42.8   50   48.78   1.21
   42.92   760   2.36   1.6   -3.8   43.05   760   14.3   250   1020   43.17   50   50.29   -0.3
   43.31   760   2.36   1.6   -3.8   43.44   760   14.3   250   1020   43.56   50   49.51   0.48
   43.69   760   2.39   1.6   -3.8   43.83   760   14.3   250   1020   43.95   50   50.23   -0.24
   44.08   760   2.36   1.6   -3.8   44.21   760   14.3   250   1020   44.34   50   49.56   0.44
   50.66   1480   13.25   9.8   14.3   50.39   1440   42.1   730   1030   50.53   57.99   58.5   -0.51
   51.05   1240   13.17   10.2   18.8   50.78   1440   41.4   700   1040   50.9   62   62.4   -0.41
   51.42   1360   16.28   12.2   5.3   51.17   1080   51.9   910   1040   51.3   60.5   60.85   -0.36
   51.81   1480   12.53   4.7   -13.5   51.56   1360   54.1   700   1060   51.69   62.09   61.14   0.94
   52.2   1440   3.53   3.1   2.3   51.94   1440   26.3   280   1070   52.08   60   61.43   -1.43
   52.6   1040   11.61   9   1.5   52.33   1360   16.5   600   1050   52.46   59.7   59.07   0.63
   52.97   1200   14.19   11.4   14.3   52.72   1120   48.9   930   1050   52.85   60.22   60.37   -0.15
   53.36   1320   9.5   2.7   -18   53.11   1240   57.9   770   1060   53.24   59.99   59.68   0.31
   53.75   1360   4.58   8.2   16.5   53.49   1360   22.6   260   1070   53.63   58.16   59.03   -0.87
   54.14   1000   13.14   10.6   5.3   53.88   1080   38.3   840   1050   54   58.78   58.01   0.77
   54.51   1120   13.67   10.6   14.3   54.27   1080   57.1   850   1050   54.39   56.82   56.66   0.15
   54.91   1200   14.72   11   18.8   54.66   1160   57.1   840   1060   54.78   58.18   58.59   -0.42
   55.3   1280   10.31   7.5   26.3   55.03   1200   49.6   660   1070   55.17   57.9   57.93   -0.03
   55.69   1320   9.89   7.1   24   55.42   1280   37.6   570   1070   55.55   56.47   55.91   0.56
   56.06   1400   23.72   20.4   8.3   55.81   1320   33.8   1030   1060   55.94   58.57   58.5   0.07
   56.45   1520   33.44   83.5   12.8   56.21   1440   84.2   1420   1070   56.33   62.05   61.51   0.54
   56.84   1680   37.56   93.3   14.3   56.58   1600   94   1470   1130   56.72   65.32   65.08   0.24
   57.24   1880   43.75   99.6   15.8   56.97   1760   97.7   1530   1210   57.09   68.92   68.26   0.66
   57.61   2080   52.61   99.6   15   57.36   1920   103   1660   1300   57.49   73.02   72.25   0.77
   58   2280   65.39   99.6   12.8   57.75   2120   115   1730   1400   57.88   77.07   77.49   -0.42
   58.39   2520   80.75   99.6   10.5   58.13   2360   128.6   1750   1560   58.27   81.27   80.38   0.89
   58.78   2800   98   99.6   8.3   58.51   2600   143.6   1740   1760   58.64   84.68   84.46   0.21
   59.16   3040   103.06   98.4   9   58.91   2880   156.4   1730   1920   59.03   87.92   87.22   0.7
   59.55   3320   102.08   99.2   13.5   59.3   3160   158.6   1700   1870   59.42   90.88   91.74   -0.87
   59.94   3600   110.03   99.6   15   59.67   3400   146.6   1670   1730   59.81   95.3   94.26   1.03
   60.33   3840   115.47   99.6   18   60.07   3680   142.9   1660   1680   60.19   100.19   99.83   0.36
   60.71   4040   121.25   99.6   19.5   60.46   3920   140.6   1660   1650   60.58   106.38   106.22   0.16
   61.09   4280   129.81   99.6   18.8   60.85   4160   139.1   1690   1620   60.97   109.5   109.44   0.06
   61.49   4520   142.75   99.6   17.3   61.22   4360   142.1   1720   1630   61.36   109.93   108.21   1.72
   61.88   4760   152.19   99.6   18.8   61.61   4600   148.1   1740   1700   61.73   109.98   108.72   1.26
   62.25   5000   157   99.6   19.5   62   4840   148.1   1750   1740   62.13   109.99   111.43   -1.44
   62.64   5240   169.36   99.6   15.8   62.39   5080   149.6   1760   1740   62.51   109.99   109.72   0.27
   63.03   5440   172.83   99.6   17.3   62.77   5280   150.4   1740   1740   62.91   109.99   108.02   1.97
   63.42   5640   177.08   99.6   18   63.16   5520   149.6   1720   1720   63.28   109.99   109.85   0.14
   63.8   5840   183.22   99.6   21   63.55   5720   148.1   1680   1680   63.67   109.99   109.58   0.41
   64.19   6040   184.56   99.6   20.3   63.94   5920   145.9   1610   1660   64.07   109.99   110.1   -0.11
   64.58   6200   182.39   99.6   21.8   64.31   6080   142.9   1550   1610   64.45   109.99   111.51   -1.52
   64.97   6400   182.47   99.6   23.3   64.71   6280   136.8   1530   1560   64.83   109.99   116.96   -6.97
   65.35   6520   183.22   99.6   24   65.09   6440   133.1   1520   1520   65.22   109.99   113.29   -3.3
   65.74   6680   183.33   99.6   24.8   65.48   6560   130.1   1510   1500   65.61   109.99   103.21   6.78
   66.12   6200   11.28   10.2   11.3   65.86   6680   128.6   770   1450   66   103.86   103.86   0
   66.52   5400   19.08   12.2   5.3   66.26   5920   15.8   290   1290   66.37   104.69   104.69   0
   66.89   4840   16.28   11   3   66.64   5160   18   290   1160   66.77   105.28   105.28   0
Thursday   17   December   2009   14:35:07
   Group A:   '003            Group B:   '115            Group C:   '114
      Engine Speed   Intake Air Mass   Throttle Drive   Ignition      Engine Speed   Engine Load   Boost Pressure   Boost Pressure      Engine Load   Engine Load   Engine Load   Wastegate (N75)
   TIME         Angle Sensor 1   Timing Angle   TIME         (specified)   (actual)   TIME   (specified)   (spec. corrected)   (actual Value)   Duty Cycle
Marker   STAMP    /min    g/s    %    °ATDC   STAMP    /min    %    mbar    mbar   STAMP    %    %    %    %
   0.06   720   2.14   1.6   -2.3   0.18   720   15   270   1010   0.32   99.2   99.2   15   0
   0.45   720   2.14   1.6   0   0.57   720   15   280   1010   0.69   99.2   99.2   15   0
   0.84   760   2.14   1.6   -3.8   0.97   720   15   270   1010   1.09   99.2   99.2   15   0
   494.62   2680   13   9   25.5   494.74   2680   23.3   410   1100   494.49   142.1   142.1   24.1   0
   495.01   2680   14.53   9.8   18   495.13   2720   24.8   420   1080   494.87   142.1   142.1   23.3   0
   495.38   2560   8.89   7.1   -4.5   495.52   2480   16.5   280   1070   495.26   142.1   142.1   20.3   0
   495.77   2360   8.31   6.3   -4.5   495.9   2320   15.8   360   1060   495.65   142.9   142.9   15.8   0
   496.16   1880   21.72   13.3   10.5   496.29   1960   47.4   630   1060   496.04   142.9   142.9   27.8   0
   496.55   1960   18.67   12.2   27   496.68   2000   42.9   730   1070   496.41   135.3   135.3   45.1   0
   496.93   2040   21.75   14.1   27.8   497.07   2040   51.1   830   1090   496.8   139.8   139.8   45.1   0
   497.32   2080   24.22   15.7   27.8   497.44   2120   53.4   830   1110   497.19   140.6   140.6   52.6   0
   497.71   2160   26.14   15.7   27   497.83   2160   54.9   830   1130   497.59   141.4   141.4   54.9   0
   498.1   2200   27.22   15.3   27   498.22   2240   41.4   500   1130   497.96   142.9   142.9   55.6   0
   498.48   2240   13.64   9.8   27.8   498.62   2280   29.3   510   1090   498.35   143.6   143.6   30.8   0
   498.87   2280   14.75   9.8   17.3   498.99   2280   28.6   470   1070   498.74   143.6   143.6   29.3   0
   499.25   2280   13.72   9.4   15.8   499.38   2280   32.3   700   1050   499.13   142.9   142.9   26.3   0
   499.65   2320   27.14   18.4   18.8   499.77   2360   60.9   1160   1070   499.51   142.9   142.9   43.6   0
   500.02   2440   48.69   28.6   20.3   500.16   2480   88   1140   1200   499.9   142.9   142.9   72.9   0.8
   500.41   2560   54.61   26.3   21   500.54   2640   91   1130   1370   500.29   142.1   142.1   91   0.8
   500.8   2720   50   20.8   21.8   500.93   2760   78.2   1000   1430   500.68   142.1   142.1   89.5   0.8
   501.19   2840   43.22   19.2   23.3   501.32   2840   72.2   930   1410   501.05   142.1   142.1   74.4   0
   501.57   2920   40.25   18   23.3   501.71   2960   66.2   930   1400   501.44   141.4   141.4   68.4   0
   501.96   3040   52.47   23.5   24.8   502.08   3080   101.5   1670   1390   501.83   141.4   141.4   66.9   0
   502.35   3200   84.86   96.5   19.5   502.47   3280   127.1   1670   1500   502.23   141.4   141.4   121.8   4.3
   502.74   3440   99.78   99.6   18.8   502.87   3520   134.6   1650   1580   502.6   141.4   141.4   129.3   16.5
   503.12   3640   108.39   99.6   18   503.26   3760   136.8   1640   1600   502.99   141.4   141.4   135.3   19.6
   503.51   3920   115.08   99.6   19.5   503.63   3960   136.8   1650   1600   503.38   141.4   141.4   136.8   19.6
   503.9   4120   118.72   99.6   21   504.02   4200   134.6   1680   1580   503.77   141.4   141.4   134.6   20.8
   504.29   4360   127.81   99.6   20.3   504.41   4440   136.8   1710   1580   504.15   142.9   142.9   136.1   21.2
   504.66   4560   132.92   99.6   21   504.8   4640   137.6   1720   1580   504.54   144.4   144.4   136.8   22
   505.05   4800   142.42   99.6   21   505.18   4880   137.6   1740   1600   504.93   146.6   146.6   136.8   23.9
   505.44   5000   147.94   99.6   21   505.57   5080   139.1   1740   1630   505.32   148.1   148.1   137.6   25.9
   505.84   5240   159.06   99.6   18   505.96   5280   142.9   1720   1650   505.69   147.4   147.4   140.6   29
   506.21   5440   166.14   99.6   18   506.35   5520   143.6   1710   1650   506.09   145.9   145.9   143.6   29.4
   506.6   5640   172.47   99.6   18.8   506.73   5720   142.9   1670   1620   506.47   143.6   143.6   142.9   29
   506.99   5840   176.25   99.6   21.8   507.12   5920   142.1   1610   1600   506.87   141.4   141.4   142.1   28.2
   507.38   6040   180.44   99.6   21   507.51   6120   140.6   1530   1580   507.24   138.3   138.3   141.4   30.2
   507.75   6160   131.5   38.8   16.5   507.9   6120   22.6   280   1590   507.63   136.8   136.8   138.3   27.1
   508.15   5640   12.25   11   7.5   508.27   5400   17.3   290   1210   508.02   139.8   139.8   13.5   0
   508.54   4960   16.44   11.4   3.8   508.66   4720   17.3   280   1130   508.41   146.6   146.6   18   0
   508.93   4440   15.56   10.6   0   509.05   4480   16.5   280   1090   508.79   145.1   145.1   16.5   0
   509.31   4440   15.83   10.6   0   509.44   4440   16.5   290   1070   509.18   144.4   144.4   16.5   0
   509.69   4400   15.92   10.6   0   509.82   4400   16.5   290   1060   509.57   144.4   144.4   16.5   0
   510.09   4360   15.36   10.6   0   510.21   4360   16.5   290   1070   509.96   143.6   143.6   16.5   0
   510.48   4320   15.89   10.6   0   510.6   4280   16.5   290   1070   510.33   143.6   143.6   16.5   0
   510.85   4280   15.72   10.6   -0.8   510.99   4280   16.5   290   1070   510.73   143.6   143.6   16.5   0
   511.24   4240   15.64   10.6   -0.8   511.36   4240   16.5   290   1070   511.12   142.9   142.9   16.5   0
   511.63   4200   15.47   10.2   -0.8   511.75   4200   16.5   290   1070   511.51   142.9   142.9   16.5   0
   512.03   4160   15.22   10.2   -0.8   512.15   4120   16.5   290   1070   511.88   142.9   142.9   16.5   0
   512.4   4120   14.97   10.2   -1.5   512.54   4080   16.5   290   1070   512.27   142.1   142.1   16.5   0
   512.79   4040   14.5   9.8   -1.5   512.91   4040   16.5   290   1080   512.66   142.1   142.1   16.5   0
   544.12   1880   6.31   5.1   -5.3   544.24   1880   15   270   1040   544   136.1   136.1   15   0
   544.51   1800   5.92   4.7   -6   544.63   1760   15   270   1030   544.36   130.8   130.8   15   0
   544.88   1720   5.5   4.3   -6   545.02   1720   15   270   1030   544.75   125.6   125.6   15   0
   545.27   1680   5.36   4.3   -6   545.4   1680   14.3   260   1030   545.14   123.3   123.3   15   0
   545.67   1680   5.42   4.3   -6   545.79   1640   14.3   260   1030   545.54   122.6   122.6   14.3   0
   546.05   1640   5.36   4.3   -6   546.18   1640   15   260   1030   545.91   122.6   122.6   14.3   0
   546.43   1600   5.33   4.3   -6   546.57   1600   15   260   1030   546.31   121.8   121.8   15   0
   546.82   1600   5.22   3.9   -6   546.94   1600   15   260   1030   546.7   121.1   121.1   15   0
   547.21   1600   5.11   3.9   -6   547.33   1560   15   260   1030   547.09   120.3   120.3   15   0
   547.6   1560   5.17   3.9   -6   547.72   1560   15   260   1030   547.46   119.5   119.5   15   0
   547.97   1560   5.03   3.9   -6   548.12   1520   15   260   1030   547.85   119.5   119.5   15   0
   548.36   1520   4.89   3.9   -6   548.49   1520   14.3   260   1030   548.24   118.8   118.8   15   0
   548.76   1520   4.75   3.9   -6   548.88   1480   14.3   260   1030   548.63   118   118   14.3   0
   549.14   1480   4.67   3.5   -6   549.27   1480   14.3   260   1030   549   117.3   117.3   14.3   0
   549.52   1480   4.61   3.5   -6.8   549.66   1440   14.3   260   1030   549.39   117.3   117.3   14.3   0
   549.91   1480   8.25   10.6   -6.8   550.04   1560   53.4   1500   1000   549.79   116.5   116.5   14.3   0
   550.3   1560   30.81   73.3   9.8   550.43   1600   88   1450   1050   550.18   117.3   117.3   72.2   94.9
   550.7   1720   36.47   95.3   13.5   550.82   1760   94   1520   1150   550.56   122.6   122.6   91.7   94.9
   551.07   1880   42.67   99.6   14.3   551.21   1960   100.8   1640   1250   550.95   128.6   128.6   95.5   94.9
   551.46   2080   52.22   99.6   15.8   551.58   2160   112   1720   1370   551.33   139.8   139.8   103.8   94.9
   551.85   2280   65.33   99.6   10.5   551.97   2400   127.1   1740   1540   551.73   142.9   142.9   117.3   94.9
   552.24   2560   83.11   99.6   7.5   552.36   2640   144.4   1730   1750   552.1   142.9   142.9   133.1   38.4
   552.61   2800   101.14   99.6   9   552.76   2920   159.4   1720   1920   552.49   142.1   142.1   149.6   38.4
   553   3080   107.08   98.4   7.5   553.13   3200   159.4   1690   1860   552.88   141.4   141.4   162.4   32.2
   553.4   3400   104.61   99.2   14.3   553.52   3480   148.1   1660   1710   553.27   141.4   141.4   154.9   25.5
   553.79   3640   114.86   99.6   16.5   553.91   3760   145.9   1650   1680   553.65   141.4   141.4   146.6   24.3
   554.16   3920   120.44   99.6   18   554.31   4000   141.4   1660   1640   554.04   141.4   141.4   144.4   22.4
   554.55   4160   124.53   99.6   19.5   554.68   4240   139.8   1700   1620   554.43   142.1   142.1   139.1   22.4
   554.94   4400   136.31   99.6   18.8   555.07   4480   145.1   1730   1650   554.82   143.6   143.6   141.4   25.5
   555.33   4680   150   99.6   18.8   555.46   4720   148.9   1740   1710   555.19   145.1   145.1   146.6   29.4
   555.71   4920   158.5   99.6   18.8   555.85   5000   147.4   1760   1730   555.58   146.6   146.6   148.9   31
   556.1   5120   166.14   99.6   16.5   556.23   5240   150.4   1740   1740   555.97   148.1   148.1   148.1   32.5
   556.49   5360   170.64   99.6   17.3   556.61   5440   150.4   1720   1720   556.37   146.6   146.6   151.1   32.9
   556.88   5600   179.11   99.6   18   557.01   5680   149.6   1690   1700   556.74   145.1   145.1   150.4   33.3
   557.26   5840   184.25   99.6   18.8   557.4   5920   148.1   1620   1660   557.13   141.4   141.4   148.1   32.9
   557.64   6040   186.67   99.6   20.3   557.77   6080   145.1   1550   1620   557.52   139.1   139.1   147.4   32.2
   558.04   6240   186.03   99.6   22.5   558.16   6280   137.6   1530   1550   557.92   136.8   136.8   141.4   29
   558.43   6400   184   99.6   23.3   558.56   6480   133.1   1510   1520   558.29   135.3   135.3   136.1   27.5
   558.8   6560   183.36   99.6   24   558.94   6640   130.1   1460   1500   558.68   133.8   133.8   133.1   27.1
   559.19   6720   183.11   95.3   24.8   559.32   6720   100   560   1480   559.07   118   118   129.3   25.1
   559.58   6280   8.69   10.2   12   559.71   6000   16.5   290   1280   559.46   133.8   133.8   16.5   0
   559.98   5480   19.25   12.2   6   560.1   5280   18   290   1160   559.83   141.4   141.4   17.3   0
   560.35   4840   16.75   11.4   3   560.49   4640   17.3   280   1110   560.22   148.1   148.1   18   0
   560.74   4280   15.78   10.6   -0.8   560.87   4080   16.5   290   1090   560.61   144.4   144.4   16.5   0
   561.13   3720   13.94   9.8   -2.3   561.26   3520   17.3   290   1080   561.01   141.4   141.4   16.5   0
   561.52   3120   14.89   7.8   -3.8   561.65   3120   15.8   290   1080   561.38   141.4   141.4   18   0
   561.9   3080   11.14   7.8   -3.8   562.04   3080   16.5   290   1080   561.77   141.4   141.4   16.5   0
   562.29   3040   10.83   7.8   -3.8   562.41   3040   16.5   290   1070   562.16   141.4   141.4   16.5   0
   562.68   3000   11.19   7.8   -3.8   562.8   3000   15.8   290   1070   562.55   141.4   141.4   16.5   0
   563.07   3000   10.64   7.5   -3.8   563.19   2960   15.8   290   1070   562.93   141.4   141.4   15.8   0
   563.44   2960   10.42   7.5   -4.5   563.58   2960   15.8   290   1070   563.32   141.4   141.4   16.5   0
   563.84   2920   10.19   7.5   -4.5   563.96   2920   15.8   290   1070   563.71   141.4   141.4   15.8   0
   564.23   2880   10.33   7.5   -4.5   564.35   2880   15.8   290   1070   564.1   141.4   141.4   15.8   0
Mapped
Thursday   17   December   2009   15:12:41
   0.25   2040   22.39   14.9   27.8   0.01   2000   49.6   760   1130   0.12   80.42   80.34   0.07
   76.83   1920   23.19   16.5   26.3   76.57   1680   56.4   890   1060   76.7   60.98   60.14   0.84
   77.22   2280   28.56   16.5   25.5   76.95   2040   54.9   910   1090   77.08   66.43   67.01   -0.58
   77.59   2200   7.33   5.5   -6.8   77.34   2360   39.1   460   1120   77.47   66.62   68.64   -2.03
   77.98   1880   11.72   11   16.5   77.73   2120   15.8   280   1090   77.86   64.82   64.33   0.49
   78.37   1640   16.28   11.4   18   78.11   1560   39.8   680   1070   78.25   69.69   68.34   1.35
   78.76   1800   9.78   5.5   31.5   78.5   1760   45.1   780   1070   78.62   74.04   74.56   -0.53
   79.14   1600   5.17   3.9   -6   78.89   1760   22.6   270   1070   79.01   71.65   73.67   -2.02
   79.53   1280   10.81   8.2   11.3   79.28   1560   15.8   260   1050   79.4   70.45   69.81   0.64
   79.92   1320   14.31   7.1   -2.3   79.66   1360   40.6   910   1040   79.8   68.3   66.77   1.52
   80.31   1400   4.44   3.1   5.3   80.05   1360   33.8   310   1050   80.17   65.78   68.14   -2.37
   80.69   1520   28.89   19.2   9.8   80.44   1400   15   260   1040   80.56   65.35   64.19   1.16
   81.08   1520   30.11   55.7   12   80.83   1400   68.4   1360   1040   80.95   69.79   69.19   0.6
   81.47   1680   35.86   72.5   15.8   81.2   1560   91   1370   1090   81.34   73.56   74.07   -0.51
   81.86   1840   42.06   71.8   15.8   81.59   1720   94.7   1410   1180   81.72   77.72   77.69   0.03
   82.23   2040   49.78   81.6   15.8   81.98   1920   100.8   1470   1260   82.11   82.23   81.93   0.3
   82.62   2240   61.89   80.4   12.8   82.37   2080   111.3   1540   1370   82.5   87.23   87.27   -0.05
   83.02   2440   76.44   75.7   7.5   82.75   2280   124.1   1560   1510   82.89   92.32   91.5   0.82
   83.41   2680   84   64.3   10.5   83.14   2520   139.1   1560   1700   83.27   96.82   97.31   -0.5
   83.78   2920   86.08   47.1   13.5   83.53   2760   142.1   1560   1770   83.66   101.91   101.8   0.1
   84.17   3160   84.14   36.9   18   83.92   3000   136.1   1540   1710   84.05   107.3   107.26   0.04
   84.56   3360   91   36.9   16.5   84.3   3240   127.8   1530   1630   84.44   109.67   110.54   -0.88
   84.95   3600   104.14   65.1   18.8   84.69   3440   126.3   1550   1600   84.81   109.94   109.96   -0.02
   85.33   3840   109.67   99.2   17.3   85.08   3680   135.3   1580   1580   85.2   109.99   112.13   -2.14
   85.72   4040   117.08   99.6   20.3   85.47   3920   135.3   1680   1580   85.59   109.99   110.5   -0.51
   86.11   4280   131.97   99.6   18.8   85.84   4120   136.8   1820   1590   85.98   109.99   108.27   1.72
   86.5   4600   192.78   99.6   11.3   86.23   4360   149.6   2000   1720   86.36   109.99   109.97   0.02
   86.88   4920   202.42   99.6   9.8   86.62   4680   191.7   2090   2230   86.75   109.99   110.29   -0.3
   87.26   5160   195.75   99.6   12.8   87.02   5000   187.2   2180   2200   87.14   109.99   108.04   1.95
   87.65   5400   207.78   99.6   12.8   87.39   5240   180.5   2150   2120   87.53   109.99   110.64   -0.65
   88.05   5640   216.67   99.6   12.8   87.78   5480   180.5   2130   2100   87.9   109.99   109.58   0.41
   88.42   5880   228.22   99.6   13.5   88.17   5720   180.5   2160   2080   88.3   109.99   110.48   -0.49
   88.81   6120   232.47   99.6   14.3   88.56   5960   178.9   2130   2070   88.68   109.99   111.7   -1.71
   89.2   6320   237.14   99.6   17.3   88.93   6200   175.9   2100   2070   89.08   109.99   107.37   2.62
   89.6   6560   238.58   98.8   18   89.33   6440   173.7   2070   2060   89.45   109.99   109.58   0.41
   89.97   6760   240.72   98   17.3   89.72   6640   169.9   2040   2030   89.85   109.99   116.89   -6.9
   90.36   6840   168.53   20.8   26.3   90.11   6800   166.2   1690   2020   90.23   109.99   107.41   2.58
   90.75   6080   11.19   11.8   10.5   90.49   6600   13.5   280   1790   90.62   121.53   121.53   0
   91.14   4840   17.11   11   2.3   90.88   5800   17.3   290   1260   91   122.58   122.58   0
   91.51   4920   16.36   11.4   3   91.26   5040   15.8   280   1150   91.39   123.34   123.34   0
   91.91   4840   17.19   11.4   2.3   91.66   4920   16.5   280   1110   91.78   123.95   123.95   0
   92.3   4800   16.94   11.4   2.3   92.03   4840   16.5   280   1090   92.18   124.5   124.5   0
   92.69   4720   17.53   11.4   2.3   92.42   4800   16.5   280   1080   92.54   124.75   124.75   0
   93.06   4680   16.92   11.4   1.5   92.81   4720   16.5   290   1090   92.94   124.95   124.95   0
Thursday   17   December   2009   15:08:06
   0.07   800   3.25   2.7   -1.5   0.19   800   18.8   320   1020   0.32   99.2   99.2   18.8   0
   104.47   1400   10.36   7.5   -10.5   104.62   1400   26.3   290   1050   104.74   120.3   120.3   20.3   0
   104.87   1440   4.25   3.5   -6.8   104.99   1360   15   260   1040   105.14   115   115   15   0
   105.26   1240   4.83   6.7   14.3   105.38   1080   24.8   550   1030   105.51   99.2   99.2   34.6   0
   105.65   1040   10.5   9   2.3   105.77   960   43.6   720   1030   105.9   100.8   100.8   42.1   0
   106.02   1080   9.69   7.8   9.8   106.16   1120   41.4   730   1030   106.29   106.8   106.8   43.6   0
   106.41   1200   12.17   10.2   21   106.54   1240   47.4   810   1040   106.68   114.3   114.3   49.6   0
   106.8   1320   14.44   11.4   24.8   106.93   1400   49.6   810   1050   107.05   119.5   119.5   48.9   0
   107.2   1480   16.5   12.5   27   107.32   1520   51.9   430   1060   107.44   125.6   125.6   37.6   0
   107.58   1440   6   3.9   -13.5   107.71   1440   17.3   260   1060   107.83   120.3   120.3   14.3   0
   107.96   1360   4.22   3.5   -7.5   108.09   1280   15   440   1050   108.23   110.5   110.5   21.8   0
   108.35   1080   8.97   7.1   10.5   108.47   1160   33.8   630   1040   108.6   106.8   106.8   38.3   0
   108.74   1160   6.25   3.5   9   108.87   1160   24.1   270   1030   108.99   109   109   18.8   0
   109.12   1160   3.64   2.7   7.5   109.26   1200   15   260   1030   109.38   108.3   108.3   15   0
   109.51   1120   3.64   2.7   -4.5   109.63   1200   14.3   990   1030   109.78   112   112   35.3   94.9
   109.9   1240   19.94   18.4   8.3   110.02   1240   66.9   1260   1030   110.15   112   112   78.9   94.9
   110.29   1280   24.97   65.9   7.5   110.41   1360   83.5   1320   1050   110.54   118   118   85   94.9
   110.66   1440   28.03   77.3   12.8   110.81   1480   87.2   1370   1100   110.93   124.8   124.8   89.5   94.9
   111.05   1600   33.11   85.9   10.5   111.18   1640   92.5   1420   1150   111.32   129.3   129.3   94   94.9
   111.45   1720   37.53   95.7   10.5   111.57   1800   96.2   1470   1220   111.69   136.1   136.1   98.5   94.9
   111.84   1920   43.28   99.6   11.3   111.96   1960   101.5   1530   1290   112.08   145.1   145.1   106   87.5
   112.21   2080   52.28   99.6   10.5   112.36   2160   113.5   1570   1390   112.48   147.4   147.4   115.8   53.3
   112.6   2280   62.11   97.3   8.3   112.73   2360   124.1   1590   1520   112.87   148.1   148.1   128.6   35.7
   112.99   2480   76.14   92.9   6   113.12   2560   137.6   1590   1700   113.24   148.1   148.1   141.4   32.5
   113.39   2720   85.86   84.3   5.3   113.51   2800   143.6   1590   1780   113.63   148.9   148.9   143.6   27.8
   113.76   2960   90.69   69   7.5   113.9   3040   143.6   1570   1730   114.02   148.9   148.9   139.1   23.5
   114.15   3200   92.53   55.7   11.3   114.27   3240   136.8   1560   1650   114.42   150.4   150.4   135.3   21.6
   114.54   3400   97.81   53.3   15.8   114.66   3480   136.1   1570   1620   114.79   151.9   151.9   136.8   20.8
   114.93   3640   105.78   85.1   14.3   115.05   3720   136.8   1640   1600   115.18   155.6   155.6   136.1   20.8
   115.3   3840   112.25   99.6   15   115.45   3920   136.1   1740   1600   115.57   159.4   159.4   135.3   22
   115.7   4080   119.39   99.6   15.8   115.82   4160   136.8   1900   1610   115.96   165.4   165.4   142.9   42.7
   116.09   4320   154.78   99.6   15.8   116.21   4400   171.4   2070   2010   116.34   172.9   172.9   182.7   55.7
   116.48   4600   194.08   99.6   6.8   116.6   4680   191.7   2150   2260   116.73   179.7   179.7   191.7   52.9
   116.85   4880   193.75   99.6   6.8   116.99   4960   185   2220   2200   117.12   185   185   182   53.3
   117.24   5120   194.75   99.6   12   117.37   5200   182   2210   2140   117.51   183.5   183.5   183.5   54.9
   117.64   5400   211.44   99.6   9   117.76   5480   183.5   2180   2150   117.89   182.7   182.7   183.5   55.7
   118.03   5640   218.81   99.6   9.8   118.15   5720   182   2210   2140   118.27   186.5   186.5   182.7   57.6
   118.4   5840   230.92   99.6   9.8   118.54   5960   182   2190   2130   118.66   190.2   190.2   182.7   59.2
   118.79   6080   234.94   99.6   10.5   118.91   6160   180.5   2150   2120   119.06   190.2   190.2   178.9   60
   119.18   6320   239.47   99.6   14.3   119.3   6360   175.9   2140   2090   119.43   190.2   190.2   175.2   61.2
   119.57   6520   243.89   99.6   14.3   119.7   6600   172.2   2060   2090   119.82   178.2   178.2   172.9   60.8
   119.95   6720   247.25   99.6   17.3   120.09   6760   175.9   1760   2050   120.21   149.6   149.6   167.7   54.1
   120.34   6880   242.06   95.7   7.5   120.47   6840   127.8   680   1920   120.6   182.7   182.7   21.1   0
   120.73   6320   14.42   9.4   12   120.85   6040   15.8   290   1330   120.98   188.7   188.7   17.3   0
   121.12   5560   18.44   12.2   6.8   121.24   5360   18   300   1170   121.37   184.2   184.2   17.3   0
   121.49   4920   17.81   11.8   3   121.63   4720   16.5   290   1120   121.76   175.9   175.9   17.3   0
   121.88   4360   15.75   10.6   0   122.01   4160   17.3   290   1090   122.15   159.4   159.4   17.3   0
   122.27   3800   14.39   9.8   -2.3   122.4   3640   16.5   300   1070   122.52   151.9   151.9   16.5   0
   122.66   3280   8.28   8.6   -3.8   122.79   3120   17.3   300   1080   122.91   148.9   148.9   16.5   0
   123.04   3080   10.78   7.8   -3.8   123.18   3040   16.5   300   1070   123.3   148.9   148.9   16.5   0
   123.43   3040   11   7.8   -3.8   123.56   3000   16.5   300   1070   123.7   148.9   148.9   16.5   0
   123.82   3000   10.64   7.8   -3.8   123.95   2960   16.5   300   1070   124.07   148.1   148.1   15.8   0
   124.21   2920   10.14   7.8   -4.5   124.34   2920   16.5   300   1070   124.46   148.9   148.9   15.8   0
   124.59   2880   10   7.5   -4.5   124.73   2880   15.8   300   1070   124.85   148.9   148.9   15.8   0
   124.98   2840   10   7.5   -4.5   125.1   2840   16.5   300   1070   125.24   148.9   148.9   15.8   0
   125.37   2800   9.83   7.5   -4.5   125.49   2800   15.8   290   1060   125.62   148.9   148.9   15.8   0
   125.76   2760   9.81   7.1   -4.5   125.88   2720   16.5   290   1060   126.01   148.9   148.9   15.8   0
   126.13   2680   9.33   7.1   -4.5   126.27   2680   16.5   290   1060   126.4   148.9   148.9   15.8   0
   126.52   2640   9.19   7.1   -4.5   126.65   2600   15.8   290   1060   126.79   149.6   149.6   15.8   0
   126.92   2600   8.81   6.7   -4.5   127.04   2560   15.8   290   1060   127.17   149.6   149.6   15.8   0
   127.31   2520   8.81   6.7   -4.5   127.43   2520   15.8   290   1050   127.56   149.6   149.6   15   0
   127.68   2480   8.75   6.7   -4.5   127.82   2480   15.8   290   1050   127.95   149.6   149.6   15.8   0
   128.07   2440   8.53   6.7   -4.5   128.2   2440   15.8   290   1050   128.34   149.6   149.6   15.8   0
   128.46   2400   8.36   6.3   -4.5   128.59   2400   15.8   290   1050   128.71   149.6   149.6   15.8   0
   128.85   2400   8.17   6.3   -4.5   128.98   2360   15.8   290   1050   129.1   150.4   150.4   15.8   0
   129.22   2360   8.03   6.3   -4.5   129.37   2320   15.8   290   1050   129.49   150.4   150.4   15.8   0
   129.62   2320   7.89   6.3   -4.5   129.74   2320   15.8   280   1040   129.88   150.4   150.4   15   0
   130.01   2280   7.72   5.9   -4.5   130.13   2280   15   280   1040   130.26   150.4   150.4   15   0
   130.4   2240   7.5   5.9   -4.5   130.52   2240   15.8   280   1040   130.65   150.4   150.4   15   0
   130.77   2280   9.97   9.8   17.3   130.91   2240   33.8   680   1030   131.04   150.4   150.4   43.6   0
   131.17   2240   28.75   19.6   17.3   131.29   2240   62.4   1170   1050   131.43   150.4   150.4   70.7   1.6
   230.17   1720   5.17   4.3   -8.3   229.92   1800   34.6   290   1090   230.04   132.3   132.3   24.1   0
   230.56   1200   4.61   3.5   14.3   230.29   1640   15   270   1070   230.43   125.6   125.6   15.8   0
   230.95   1320   10.81   9.8   3.8   230.68   1280   15.8   260   1050   230.8   114.3   114.3   14.3   0
   231.32   1360   19.72   16.5   13.5   231.07   1320   41.4   1150   1030   231.19   115.8   115.8   58.6   5.5
   231.71   1480   29.89   51.8   16.5   231.46   1400   63.2   1330   1060   231.58   121.1   121.1   73.7   94.9
   232.1   1640   34.14   82.7   15   231.83   1520   88.7   1360   1080   231.98   126.3   126.3   91.7   94.9
   232.49   1800   38.81   83.5   12   232.22   1680   94   1400   1160   232.35   130.1   130.1   95.5   94.9
   232.87   1960   45.78   89   12   232.62   1840   98.5   1460   1240   232.74   139.8   139.8   100   94.9
   233.26   2160   56.19   91.4   15   233.01   2000   106.8   1540   1320   233.13   148.1   148.1   110.5   75.3
   233.65   2360   70.64   85.5   8.3   233.38   2200   118   1570   1440   233.52   150.4   150.4   121.8   33.7
   234.04   2600   82.67   73.7   10.5   233.77   2440   131.6   1570   1610   233.9   149.6   149.6   136.1   32.5
   234.42   2840   88.42   63.5   7.5   234.17   2680   142.9   1570   1770   234.29   148.9   148.9   142.9   28.2
   234.81   3080   87.39   41.6   10.5   234.56   2920   142.9   1560   1760   234.68   148.1   148.1   140.6   23.1
   235.19   3320   88.78   38.4   15.8   234.93   3160   132.3   1550   1670   235.07   149.6   149.6   130.1   20.8
   235.59   3520   102.53   56.1   18.8   235.32   3360   127.8   1550   1620   235.44   150.4   150.4   128.6   19.2
   235.96   3760   108.86   95.3   15.8   235.71   3600   135.3   1570   1600   235.83   154.1   154.1   136.8   18.4
   236.35   3960   116.25   99.6   19.5   236.1   3840   135.3   1660   1590   236.22   157.9   157.9   134.6   19.6
   236.74   4200   124.75   99.6   16.5   236.48   4040   136.1   1770   1590   236.62   162.4   162.4   136.8   22
   237.14   4480   185.36   99.6   10.5   236.87   4280   141.4   1950   1630   236.99   169.2   169.2   153.4   49
   237.51   4800   203.31   99.6   9.8   237.26   4560   186.5   2080   2150   237.38   177.4   177.4   191.7   52.9
   237.9   5040   193.42   99.6   12.8   237.65   4840   191.7   2150   2250   237.78   185   185   187.2   49.8
   238.29   5280   204.31   99.6   9.8   238.02   5080   180.5   2180   2120   238.16   184.2   184.2   180.5   51.4
   238.68   5560   216.67   99.6   9.8   238.41   5360   182   2150   2130   238.54   182   182   182   52.2
   239.05   5760   220.69   99.6   10.5   238.8   5600   181.2   2150   2110   238.93   185   185   180.5   53.3
   239.44   6040   232.14   99.6   12   239.2   5880   180.5   2180   2080   239.32   189.5   189.5   182   55.7
   239.83   6240   237.72   99.6   15   239.57   6080   178.9   2120   2080   239.71   190.2   190.2   178.2   56.5
   240.23   6440   237.78   99.6   15   239.96   6320   175.9   2120   2070   240.09   190.2   190.2   174.4   57.6
   240.6   6640   245.22   98.8   15   240.35   6520   171.4   2090   2060   240.47   188   188   171.4   58.4
   240.99   6800   227.94   42.7   14.3   240.74   6720   171.4   1840   2060   240.87   152.6   152.6   166.2   54.1
   241.39   6560   17.83   8.6   13.5   241.11   6840   147.4   1530   2230   241.26   149.6   149.6   49.6   0
Offline Sunglasses Ron
« Reply #164 on: December 18, 2009, 11:13:03 am »
That's because he is a VAG SLAG and can't get enough of it, ey Al?  :rolleye: :grin:
