Author Topic: revving issue  (Read 1007 times)
Offline tomolambo
  • points mean prizes
revving issue
« on: May 07, 2015, 09:02:42 pm »
hi
having a weird issue with my car, when i change gear the revs creep up 500rpm it has been happening for the last 2 weeks, i have smoke tested my car for air leaks with no fault checked for codes none present changed my clutch pedal position sensor and still joy, and just noticed my cruise control has stopped working so a assume that there related.
has anyone else experienced a fault like this?
cheers tom
Offline Blackgtiman
Re: revving issue
« Reply #1 on: May 07, 2015, 09:55:20 pm »
what application did you use yto check for faults? a lot of aftermarket apps are crap and don't show actual stored faults. you'll ideally need vagcom.
Offline tomolambo
Re: revving issue
« Reply #2 on: May 07, 2015, 10:14:52 pm »
a up to date vcds
also forgot to mention when revving at idle it is completely fine
Offline l2azvan
Re: revving issue
« Reply #3 on: August 08, 2016, 11:07:24 am »
old topic but same problem.
what was the issue ?
