Author Topic: Nqs bbk problems  (Read 1581 times)
Offline Nato
Nqs bbk problems
« on: May 08, 2015, 12:15:54 am »
I have fitted nqs bbk to my edition 30 with 3mm st spacers and I now have a vibration through steering wheel over 70mph ?? Any ideas what could be problem ??
Offline dan930
  • -Receive: 56
Re: Nqs bbk problems
« Reply #1 on: May 08, 2015, 12:32:09 am »
Most probably it be your spacers mate...I've had the same problem before,changed to hubcentric spacers & no steering vibration afterwards
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline Nato
« Reply #2 on: May 08, 2015, 12:41:14 am »
cheers for reply Dan. The St spacers I bought were from awesome Gti and are specific to the 57.1 bore of wheel hub, I had universal ones on before and vibration was much worse. what size and make were your hubcentric spacers ?? I also put 3mm longer wheel bolts on with new spacers.
dansmith180
« Reply #3 on: May 08, 2015, 08:23:40 am »
Did you fit the spacers the right way around? With the flat surface facing outwards and the bit that looks like it's been countersunk facing in towards the hub? I but some on wrong once and it vibrated.
Offline Nato
« Reply #4 on: May 08, 2015, 02:07:52 pm »
Spacers on right way???
Offline dan930
  • -Receive: 56
« Reply #5 on: May 08, 2015, 02:23:19 pm »
8mm H&R hubcentric mate
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline mvb12
  • -Receive: 64
« Reply #6 on: May 08, 2015, 09:43:37 pm »
Mate with a 3mm spacer the wheel should still sit on the hub you checked the balancing at all?
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #7 on: May 09, 2015, 05:55:46 am »
Alex AKS has some spigot extenders that work a treat
Offline Nato
« Reply #8 on: May 09, 2015, 10:39:28 pm »
Balancing next thing... cheers dave I'll give him a buzz cheers for info!!
Offline Nato
« Reply #9 on: May 13, 2015, 09:53:56 pm »
Daveb any idea who else does spigot extenders as I can't get a hold of Alex aks. I take it aks tuning is who I contact??
  • -Receive: 427
« Reply #10 on: May 13, 2015, 11:11:38 pm »
^^^^ Yes, AKS Tuning.  :happy2:
