Author Topic: Accidentally stuck in 3rd gear at high speed !  (Read 1472 times)
Offline jhook661
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98678.0.html
« on: May 08, 2015, 09:35:52 pm »
As above I was was giving it some and i accidentally stuck it in 3rd instead of fifth and the revs went to 8000 k !!  :sick: for a split second ! Would I have done any damage still feels perfect And no noise or anything  :scared:
Modded Golf gti CDL engine TTE420 turbo
Rtech 440bhp 429ftlb
Offline cooljimy84
    • Personal
Re: Accidentally stuck in 3rd gear at high speed !
« Reply #1 on: May 08, 2015, 09:40:47 pm »
Done that in my mk4, was fine.
Did it in my Honda Civic (F reg) and broke the dizzy (yes it was a crappy 1.5 civic....)
Not much you can do part from drain the oil and check for lumps of metal...
Or pull the engine apart and have a look.....
There is no replacement for displacement....
But a turbo does help....
dansmith180
« Reply #2 on: May 08, 2015, 09:52:48 pm »
Yeah I would change both the engine and gearbox oil ASAP and have a good look through then, these things are pretty strong so you may get away with it. Fingers crossed for you mate.
Offline andybon
« Reply #3 on: May 08, 2015, 09:55:00 pm »
It should be fine doing it just the once, if you are doing it constantly then that's where the problems start.
I suppose it's one way of blasting the crap out of the engine,  :laugh:
How hard can it be?
Offline howie1987
  • -Given: 92
  • -Receive: 20
« Reply #4 on: May 08, 2015, 10:06:27 pm »
Sounds like you got lucky lol. Would change oil etc as said above though.
Offline Blackgtiman
« Reply #5 on: May 08, 2015, 10:19:13 pm »
no point changing oils.... if it still runs ouve been lucky if there are noises get your wallet out.
Kam88
« Reply #6 on: May 08, 2015, 10:43:18 pm »
don't bother changing anything if works as before and no noises don't change it.
If you hearing noises drain oil and check it over
Offline Paulo P
« Reply #7 on: May 08, 2015, 11:17:14 pm »
I did a similar thing on my old Integrale a long time ago but I hit 2nd instead of 4th at quite high speed and a few months later the cam belt jumped a tooth or 2 and destroyed the engine, to this day I do not know if that was a result of hitting 2nd and the engine hitting best part of 9,000rpm (calculated) briefly.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #8 on: May 09, 2015, 01:18:34 am »
You should get it checked over mate. That could have caused piston to touch valve  :sick:
Offline jhook661
  • -Receive: 20
« Reply #9 on: May 09, 2015, 07:55:44 am »
Thanks all for your feedback I think I'll changing the oil today and see how it goes if it does blow any excuses for s3 engine  :happy2:
Offline vRSAlex
  • -Receive: 253
« Reply #10 on: May 09, 2015, 08:05:57 am »
Vagcom will tell you exactly what rpm you hit.
I've seen rockers jumping off, valves snapping, valve springs snapping, belts jumping from over reving.
Follow AKS tuning on Facebook
Offline jhook661
  • -Receive: 20
« Reply #11 on: May 09, 2015, 08:10:04 am »
Still runs spot on though ? Lucky ?
Offline jhook661
  • -Receive: 20
« Reply #12 on: May 09, 2015, 11:11:10 am »
Just did a compression test on all the cylinders are bang on 13bar I'm guessing that's what there meant to be on ?
