November 16, 2024, 08:58:34 pm
All Things Mk5
Mk5 General Area
HPFP banjo bolt
Topic: HPFP banjo bolt (Read 2326 times)
GTIEagles
Won't Shut up.
-Given: 10
-Receive: 22
HPFP banjo bolt
May 10, 2015, 06:29:25 pm »
I was going to attempt changing the cam follower today naively thinking I had the a M8 triple square in my toolkit but I didn't. Looking on the internet I found this
http://www.ebay.co.uk/itm/BGS-1-2-Spline-XZN-M8-x-53-mm-Bit-Socket-Non-Tamper-Pro-Range-/281516898926?pt=LH_DefaultDomain_3&hash=item418bb6fa6e
Would this do the job?
mk5-beast-91
Always Involved
-Given: 5
-Receive: 14
instagram: subarukid24
Re: HPFP banjo bolt
Reply #1 on:
May 10, 2015, 06:43:37 pm »
Have to take the insert out off the socket and use a spanner to turn it as its a very tight fit. I took mine out and taped it into a 1/4 inch spanner.
my strength lies solely in my tenacity
jhook661
Always Involved
-Given: 16
-Receive: 20
My Ride:
Re: HPFP banjo bolt
Reply #2 on:
May 10, 2015, 06:49:10 pm »
How I did it a 10mm ratchet spanner and a m8 triple square but the separate m8 triple square and a little bit of tape on it
Try Halfords or a car part motor factors
Hope this helps
Modded Golf gti CDL engine TTE420 turbo
Rtech 440bhp 429ftlb
GTIEagles
Won't Shut up.
-Given: 10
-Receive: 22
Re: HPFP banjo bolt
Reply #3 on:
May 10, 2015, 07:14:26 pm »
Thanks guys, so I guess this would work better then?
http://www.ebay.co.uk/itm/M8-SPLINE-BIT-12-Point-Socket-10mm-Hex-Drive-30mm-long-/160537280459?pt=LH_DefaultDomain_3&hash=item2560c47fcb
GTIEagles
Won't Shut up.
-Given: 10
-Receive: 22
Re: HPFP banjo bolt
Reply #4 on:
May 10, 2015, 07:29:57 pm »
Attached onto this?
http://www.wilko.com/hand-tools/wilko-spanner-w-hratchet-10mm/invt/0343588
I have a normal 10mm spanner does the ratchet make it much easier?
mk5-beast-91
Always Involved
-Given: 5
-Receive: 14
Re: HPFP banjo bolt
Reply #5 on:
May 10, 2015, 08:01:52 pm »
Alot easier. Youll only get a tiny turn each time so ratchet spanner will defo help.
All Things Mk5
Mk5 General Area
HPFP banjo bolt
