Author Topic: Help With Fault Codes  (Read 1090 times)
Kam88
« on: May 11, 2015, 10:07:14 pm »
Hi everyone needs some clarity i had my midline swapped for highline cluster and since i have scanned my car and it comes up with the following faults which i don't think affect the car. Can i get rid of these or will they forever be there simply because the car has had clock swap ?
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006589897
   Coding: E78F8F2700041500471400001400000000087F075C0001
   Shop #: WSC 00000 785 00200
   VCID: 6CD1B4F24FFC9D7E575-8039
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 201206 020  0501
   Coding: 00038805
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     170107 020  0105
   Coding: 00208933
   Shop #: WSC 00000
1 Fault Found:
01800 - Light Switch (E1)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 233
                    Mileage: 90440 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.65 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0G8016281
   Coding: 0007403
   Shop #: WSC 01286 386 08256
   VCID: 316F6586A85E3096243-8064
1 Fault Found:
00003 - Control Module
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1610
   Shop #: WSC 00000 000 00000
1 Fault Found:
            014 - Defective
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 89402 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:33:49
Any suggestions ??
