Author Topic: condensation thoughts  (Read 1640 times)
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
« on: May 11, 2015, 10:32:04 pm »
Washing my car earlier and once again my back window condensates up in the same spot. Is it known for a leak to happen from the wiper arm or is it just a warm car with cold water running over the glass?
It's only started doing it.
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
Re: condensation thoughts
« Reply #1 on: May 11, 2015, 10:39:53 pm »
Never had it but my guess is you need a new wiper arm seal
Offline Horatio
  • -Receive: 39
« Reply #2 on: May 11, 2015, 10:51:13 pm »
warm air inside the car rises, hits the glass and condensates, if youve used a power washer water has got inside the car, probably a tiny-tiny amount unless you noticed the car wet inside. Current mk5 and previous VW's have all done it. Mine is the same in both corners of the rear passenger doors, not so much on the boot.
Offline Alex157_gti
  • VCDS 2015 Edition
  • My Ride: Focus ST
« Reply #3 on: May 11, 2015, 11:35:18 pm »
Mine does it a little on passenger door (5door) front window
Strange but goes after the car is dry 10mins later not worries yet aha!
2005 Gti Black 18" monzas, full leather, sunroof, sat nav, heated seats. highline, high spec
Sheffield.
VCDS 2015 Edition Hex+Can Can help out
Offline GTiBlues
  • Mr Blues
    • Bookface
« Reply #4 on: May 12, 2015, 08:11:28 pm »
It does go pretty quick.
I originally thought it was my aerial as it was loose. Tightened it up and didnt stop this from happening. The car is dry so I know theres no leaks etc, only used the hose pipe.
As mention above, wiper arm seal possibly.
Offline RedGolfDom
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99951.0.html
« Reply #5 on: May 13, 2015, 03:29:13 pm »
Just do a wiper delete it looks much cleaner with no wiper there! Plus all that rear wiper does is dirty your window  :happy2:
Mk5 golf gt 140
Revo stage 1
Air lift Performance 3p
Offline Matthewsimone
  • -Receive: 39
« Reply #6 on: May 13, 2015, 04:32:01 pm »
Mine doesn't do it and wash car most weeks
 :scared:
  • -Receive: 39
« Reply #7 on: May 13, 2015, 04:46:52 pm »
Never understood this
How does removing the rear wiper and sticking a tacky plastic cap in the hole make it look cleaner  :laugh:
Apart from the fact that the rear wiper does quite a important job given that the rear of golfs seem to really pick up dirt in wet conditions etc how do you come to the conclusion that it makes the rear screen dirty!
Sounds like you need a new rear wiper blade mate as mine cleans the screen perfectly  :rolleye:
Offline RedGolfDom
« Reply #8 on: May 13, 2015, 05:41:11 pm »
Just something about no wiper which makes it look much smoother without a horrible big wiper arm! And it's not the end of the world if your back window was literally covered in mud as vans don't even have back windows so it's not a necessity. just my opinion anyway  :smiley:
Mk5 golf gt 140
Revo stage 1
