November 26, 2024, 11:59:36 am
All Things Mk5
Mk5 General Area
Good auto electrician needed in Leeds area
Topic: Good auto electrician needed in Leeds area (Read 1307 times)
toplad
Taking part
-Given: 6
-Receive: 0
May 12, 2015, 01:02:37 pm »
Hi all
I have a reverse light out, I've checked it with a tester and there's is no voltage there when in reverse. Also checked the cable which goes through the hatch, all fine.
Does anyone know a decent auto electrician around Leeds/Bradford?
Dan_FR
Just look at my post count
-Given: 132
-Receive: 189
wait...what?
Re: Good auto electrician needed in Leeds area
Reply #1 on:
May 12, 2015, 01:41:19 pm »
Check the reverse switch on the gearbox with a multimeter
TFSI... Revo Stage 2+... . WMI.... VCDS HEX + CAN, MPPS, VAG Commander & VAG tacho - South Wales
Johnboy2110
Always Involved
-Given: 10
-Receive: 2
Reply #2 on:
May 12, 2015, 02:43:24 pm »
autolec HD in Huddersfield, top lads.
toplad
Taking part
-Given: 6
-Receive: 0
Reply #3 on:
May 12, 2015, 04:03:59 pm »
Quote from: Dan_FR on May 12, 2015, 01:41:19 pm
Can I do this from above or do have to check from the underneath ?
toplad
Taking part
-Given: 6
-Receive: 0
Reply #4 on:
May 12, 2015, 04:05:29 pm »
Quote from: Johnboy2110 on May 12, 2015, 02:43:24 pm
Cheers johnboy Was hoping for someone near thou
toplad
Taking part
-Given: 6
-Receive: 0
Reply #5 on:
May 13, 2015, 07:29:51 pm »
Anybody help me out with this?
Dan_FR
-Given: 132
-Receive: 189
wait...what?
Reply #6 on:
May 14, 2015, 09:21:22 am »
Just check to see if the reverse light switch on the gearbox is doing anything. Needs to be checked from underneath. You will have an ignition live (one wire goes live when ignition is on) and then a switched earth when reverse is engaged (open circuit when not in reverse).
Any half tidy garage will get to the bottom of this in no time, it's a very simple circuit. Doesn't need a dedicated auto-electrician
toplad
Taking part
-Given: 6
-Receive: 0
Reply #7 on:
July 22, 2017, 09:37:29 am »
Thanks sorted it
All Things Mk5
Mk5 General Area
