Author Topic: Powerflex anti lift kit  (Read 10618 times)
Offline al200
« on: May 12, 2015, 06:49:26 pm »
Has anyone had this fitted? Would really like some feedback on your experiences as may be getting it fitted next week instead of a whiteline kit.
Any views much appreciated! Just not much out there on the powerflex version of the anti lift kit.
Offline al200
Re: Powerflex anti lift kit
« Reply #1 on: May 12, 2015, 07:48:18 pm »
Anyone???
Offline Edition30nick
« Reply #2 on: May 13, 2015, 07:16:02 am »
Absolutely amazing!!
Offline olethalb
  • -Receive: 31
  • My Ride: A4 DTM - TOURAN
« Reply #3 on: May 13, 2015, 08:39:15 am »
asked the same question on FB TFSI tuning page, no one on there had tried them either, once i've bought a few other bits on the list i'll be trying them out.
i prefer the modified mount tha the offset bush - seems a better solution.
Touran TFSI Quattro | stage 2+ BHZ | UK's first
Offline olethalb
  • -Receive: 31
« Reply #4 on: May 14, 2015, 12:23:47 pm »
just bought them from awesome so will report back once they're fitted  :happy2:
Offline JP
« Reply #5 on: May 14, 2015, 02:23:54 pm »
I was interested in this kit, I will keep an eye out for your response.
Offline olethalb
  • -Receive: 31
« Reply #6 on: May 14, 2015, 03:08:27 pm »
i'll try and get them on at the weekend, the current stock (genuine) items are 6 months old and trashed, i'm fighting the steering every time i step on the loud pedal
Offline AlexK1
« Reply #7 on: May 14, 2015, 03:11:06 pm »
I remember seeing that post about the powerflex bushes, I'm in the same boat. Want to change to them but could t find any reviews on them.
Be good to see how you get on with them, anything will be better than the stock ones!
Offline olethalb
  • -Receive: 31
« Reply #8 on: May 14, 2015, 03:31:13 pm »
as long as they don't ruin the ride of the bus, i'm on 225/35/19's with powerflex front wishbone bushes, powerflex db bush, new stock engine mounts, new ball joints / track rod ends / droplinks, VWR front ARB and new AP coils
when 'off power' it drives perfectly normally, smooth, not harsh or crashy at all. really is nice to drive, hopefully these won't make it too thumpy over bumps / drains, i'm very happy with the ride at the mo.
i will update as and when, initial thoughts and after a week or so after they've bedded in a bit.
Offline olethalb
  • -Receive: 31
« Reply #9 on: May 18, 2015, 08:25:08 am »
They arrived at the end of last week
So saturday removed old units and compared
Then fitted
And my 3rd geo in a month
Offline olethalb
  • -Receive: 31
« Reply #10 on: May 18, 2015, 08:35:06 am »
ok so having used them for mixed driving for 2 days, 50 miles country b roads, 20 miles dual carriage ways cruising and fair share of hooning i'm happy.
obviously there is still wheel spin but a lot less fighting the wheel and it definately hooks up better
they are slightly more harsh (understandably) mainly over manholes and particularly ridges in the road that both wheels hit at the same time but not as bad as i was expecting
turn in is slightly better aswell
car feels more planted and definately more stable under heavy braking
oddly enough the old bushes (6 month old genuine) showed no sign of wear or tears, i guess the compound is just not up to the job
so;
slightly harsher ride
better grip in turns
more stable
almost no squirl under heave braking
almost no more wheelie action
massively reduced torque steer
wheel spins reduced and more controllable
so far so good  :happy2:
will report back in a week or so when i've put some more miles see how they're settling in  :driver:
Offline al200
« Reply #11 on: May 18, 2015, 10:20:26 am »
Thanks for this. May consider it, instead of the whiteline equivalent.
Offline al200
« Reply #12 on: May 18, 2015, 10:34:08 am »
How easy was this to fit?
Offline olethalb
  • -Receive: 31
« Reply #13 on: May 18, 2015, 11:27:44 am »
not too bad on a jack on the floor, old ones took a bit of persuasion to remove.
the hardest part was lining the bolt holes up after, just took a well placed lever bar and a little patience, i think took 45 mins all in including photoshoot  :grin:
i would have honestly preferred to use stock bolts rather than the allen head bolts, just makes me nervous if they sieze and you want to remove them will be ball ache.
but so far a very worthwhile mod  :happy2:
Offline al200
« Reply #14 on: May 18, 2015, 01:19:25 pm »
Thanks for the info. Think it could be the first review of this on the net.
