September 27, 2024, 04:27:14 pm
All Things Mk5
Mk5 General Area
Mk5 Gti Cruise Control
Pages:
3
Topic: Mk5 Gti Cruise Control (Read 10285 times)
Dobbsy
Taking part
-Given: 2
-Receive: 0
Re: Mk5 Gti Cruise Control
Reply #15 on:
June 04, 2015, 09:34:46 pm »
Hi guys
All fitted, but tried it up the road and doesn't seem to work,
Programmed using vag comm but now get the following error
RetroRaz
Just look at my post count
-Given: 32
-Receive: 194
Reply #16 on:
June 04, 2015, 10:58:05 pm »
does the green light come up on the dash when cruise is switched to the ON position?
Also did you enable CC in the engine coding using VCDS, and was the wire fitted?
#RetroRaz -
https://instagram.com/retroraz/
Dobbsy
Taking part
-Given: 2
-Receive: 0
Reply #17 on:
June 05, 2015, 01:15:19 pm »
Thanks for the reply,
No the light doesn't come on, I have enabled it in vag com , I haven't added any wiring, when I checked behind the window wiper I didn't have any plugs in there to run the wire, have I missed a step on wiring ?
Rossimac
Won't Shut up.
-Given: 78
-Receive: 33
My Ride:
Reply #18 on:
June 05, 2015, 02:23:51 pm »
Some very early 2007 cars don't have the wire as far as I remember - what build month is yours?
Did you code both the Engine as well as tick the box for Cruise Control?
Dobbsy
Taking part
-Given: 2
-Receive: 0
Reply #19 on:
June 05, 2015, 06:08:12 pm »
Ah right which cable to I need to add ? Or check to see if I have ?
I went into engine and added cruise control on the tick box only,
It's a 57 plate but don't know exact month sorry
fab5freddy
-Given: 238
-Receive: 239
Reply #20 on:
June 05, 2015, 07:29:59 pm »
Did you check that your steering wheel control module was compatible for cruise control?
Dobbsy
Taking part
-Given: 2
-Receive: 0
Reply #21 on:
June 05, 2015, 09:07:27 pm »
Ah no,
Is there a topic I can look at to check ?
Thanks again
fab5freddy
-Given: 238
-Receive: 239
Reply #22 on:
June 05, 2015, 09:20:17 pm »
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
Dobbsy
Taking part
-Given: 2
-Receive: 0
Reply #23 on:
June 06, 2015, 07:51:56 pm »
Thanks for that will have a look in the week see which one I have
Rossimac
Won't Shut up.
-Given: 78
-Receive: 33
My Ride:
Reply #24 on:
June 06, 2015, 09:17:17 pm »
Being a 57 plate, it'll most likely be a build date of mid-2007 so you should be fine for the wire being present. As said above, make sure you've got the correct steering control module.
Dobbsy
Taking part
-Given: 2
-Receive: 0
Reply #25 on:
June 11, 2015, 10:10:35 pm »
Hi
Just had a quick look and took a picture of what it has can anyone tell me if its compatable ?
fab5freddy
-Given: 238
-Receive: 239
Reply #26 on:
June 11, 2015, 10:20:01 pm »
Yep "AQ" is a Highline module so you should be fine with that
Dobbsy
Taking part
-Given: 2
-Receive: 0
Reply #27 on:
June 11, 2015, 11:09:10 pm »
Ah right cool, wonder what I've missed and why I have that code error ?
omeydz
Won't Shut up.
-Given: 3
-Receive: 50
Reply #28 on:
June 12, 2015, 08:16:48 am »
So you have coded the engine and the steering electrics?
You should have a G visible in the engine component field.
If you post up your coding for your steering electrics and see how you have coded it.
If all the coding is correct then theres small chance the AQ module may not support cruise. Remember a thread ages ago where Eddie-nl said an early highline sometimes supported cruise and sometimes not. Think it was AQ module that was referred to. So maybe try different steering controller.
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Dobbsy
Taking part
-Given: 2
-Receive: 0
Reply #29 on:
June 12, 2015, 01:31:52 pm »
ok thanks,
As soon as I can borrow Vag Com again I will post it up.
Pages:
3
All Things Mk5
Mk5 General Area
