September 22, 2024, 08:28:15 pm
All Things Mk5
How to Guides / Troubleshooting
Center caps at the rear wheels doesn't fit
Topic: Center caps at the rear wheels doesn't fit (Read 1381 times)
TheDGM
Taking part
-Given: 1
-Receive: 1
May 15, 2015, 04:10:16 pm »
Recently I bought aftermarket wheels but now I have a problem with fitting the center caps at the rear wheels. At the front there's enough space, but at the rear wheels not.
Front:
Rear:
Is there an easy solution?
Last Edit: May 15, 2015, 05:50:11 pm by TheDGM
4ndy
Re: Hub caps at the rear wheels doesn't fit
Reply #1 on:
May 15, 2015, 04:27:08 pm »
17mm black plastic off the ebay Or a better option is to get studs and lugs
TheDGM
Taking part
-Given: 1
-Receive: 1
Reply #2 on:
May 15, 2015, 05:49:36 pm »
Sorry i mean center caps!
TheDGM
Taking part
-Given: 1
-Receive: 1
Re: Center caps at the rear wheels doesn't fit
Reply #3 on:
May 18, 2015, 06:54:47 pm »
Anyone?
Carpy25
Always Involved
-Given: 11
-Receive: 40
Reply #4 on:
May 18, 2015, 07:13:27 pm »
flat caps wont fit you need something like this
http://www.ebay.co.uk/itm/SMITHS-nemesis-alloy-wheel-domed-relief-center-caps-ideal-universal-fitment-60mm-/281219529852?pt=LH_DefaultDomain_3&hash=item4179fd7c7c
these may be domed enough
http://www.ebay.co.uk/itm/VW-Volkswagen-55mm-3D-Domed-Centre-Caps-X4-1st-Class-P-P-Golf-Polo-Passat-Lupo-/361214457310?pt=LH_DefaultDomain_3&hash=item541a0f35de
your other option if you have room is to fit a spacer that will move the flatface in out of the way , but you may need longer bolts as well as spacers then
Rob
Last Edit: May 18, 2015, 07:17:52 pm by Carpy25
All Things Mk5
