Author Topic: JD's 2004 Reflex Silver Golf GT TDI  (Read 4113 times)
Offline JD2032
« on: May 17, 2015, 11:46:40 am »
Hello everyone, I currently own a 2004 Mk5 Golf GT TDI in Reflex Silver.
Sadly I don't have many pics, after moving house and changing phones (Silly iOS...Should probably get an actual digital camera)
I've owned this car for getting on 3 years now and it's been a interesting series of events!
Some Facts and Figures ;
From Purchase -
2004 Golf Mk5 GT TDI, 140 BHP, BKD Engine. I picked it up on around 89,000 miles
Standard equipment was just;
Full leather heated interieor.
Heated but non folding side mirrors
Other than that it was quite the poverty spec but at the time I was trading up from a Mk4 1.4 16V Golf so this was more than enough to keep me happy!  :driver:
Current Mod's
The first mod that was carried out was a Caronio cold air intake down to behind the fog - I know air intakes don't really do much for TDI's but I like the sound it produces and my intake temps did drop a little and the car felt more responsive in my opinion so I was happy.
This is where the modding bug began.
Stage 1 Generic Map:
It was then booked into the guys at Awesome GTI in Manchester for a generic stage 1 remap and EGR delete.
Didn't get it on the dyno at the time, but was assured that it would now be producing around 170-190 BHP, certainly feels more towards the higher end as I had a good lead over a friends BMW that was near new and produced 180 BHP from factory.
Milltek Turbo Back Non Res Exhaust:
After this, it was time for a new exhaust system. I opted to go for the full Milltek turbo back non resonated setup, again from the guys at Awesome.
This certainly seemed to improve the performance of the car, I guess through a free flowing exhaust gases and the like, but probably not using it to its full extent due to only being a generic map. The noise produced is nice too, not too over the top, not as loud as some setups I've seen bolted to the likes of Corsa's and Saxo's around my area! But more refined and noticeable when really giving it the beans!
Whiteline Anti Lift Kit:
This was fitted on a bit of whim, didn't really understand how it worked or how it would help but it certainly seemed to improve my cornering, gave me a bit more confidence.
The above mod's were all carried out in my 1st year of ownership, but nothing has really happened since then!
Present Plans:
I've recently purchased the following, which are either on their way to be deliver or sat in my spare room!
VW Racing Front Anti Roll Bar
VW Racing Rear Anti Roll Bar
A series of new powerflex bushes for the front and engine inserts
Standard Golf GTI Front Brake setup
New Tarox drilled and grooved front discs
New Tarox front pads
Standard Golf GTI Rear Brake Setup
New Tarox drilled and grooved rear discs
New Tarox rear pads
18" Alloy wheels
I told myself I "Needed" these, could of gone with 17"s to clear the new brake upgrades but I told myself I needed the 18's instead!...Just don't tell the Mrs!
Future Plans:
Thinking the next steps will be sorting out the rear bumper, it's a GTI valance on their at the moment, but it's in black. Perhaps a colour code but I keep changing my mind if the full colour code looks good or not!
I really fancy the highline clocks too with Polar FIS maybe!, but I guess I'd need a multi-function steering wheel for this too!
RNS or RCD headunit, got a aftermarket headunit in at the moment and while it looks ok, it doesn't really do it for me anymore!
  • -Receive: 442
Re: JD's 2004 Reflex Silver Golf GT TDI
« Reply #1 on: May 17, 2015, 12:31:14 pm »
Some nice mods thier..Have a look through my build thread and also the Mrs doesn't know half of my mods :signLOL:
Offline th3_f15t
  • -Receive: 183
« Reply #2 on: May 17, 2015, 01:08:47 pm »
Correct me if I'm wrong, but the GTI front brakes won't fit your current set up as your car has 50mm struts where the GTI brakes need the 55mm set up so you'll need new hubs too?
  • -Receive: 442
« Reply #3 on: May 17, 2015, 01:28:12 pm »
The gttdi golf uses 55mm strut and is the same hub as the gti and will fit perfectly..The calipers are also the same and you just need to change the carriers for the bigger discs
Offline JD2032
« Reply #4 on: May 17, 2015, 01:42:30 pm »
Thanks for confirming this, I thought this was the case! Just frantically checked the car for any stickers or anything to identify it and couldn't!
But all the sources I checked said it would be 55mm strut on the GT TDI Models, rule of thumb being if its 2.0 litre and above its 55mm as doesn't the BMM 170 TDI have Gti brakes?
1.9's and below have 50mm struts I think
  • -Receive: 442
« Reply #5 on: May 17, 2015, 02:00:05 pm »
Yeah all correct
Offline JD2032
« Reply #6 on: May 17, 2015, 02:17:11 pm »
Yeah all correct
Sweet...I know something !  :pomppomp: :pomppomp: :pomppomp:
Offline th3_f15t
  • -Receive: 183
« Reply #7 on: May 17, 2015, 03:10:38 pm »
I got confused and didn't acknowledge yours was a GT TDI. My bad, sorry to scare you.
Offline JD2032
« Reply #8 on: May 17, 2015, 04:46:16 pm »
I literally read your post...had a   :surprised: :surprised: :surprised: :surprised: :scared: :scared: :scared: :scared: moment, ran outside, checked the car and was very confused !  :confused:
Crisis averted thanks to Maxitrol!
Offline JD2032
« Reply #9 on: May 21, 2015, 04:33:16 pm »
New Alloys !!!!!
Today was a good day...the sun is shining, it's almost the weekend and I've had my new wheels fitted !
I've gone from this...
To these..........
Pride of my place, outside my digs.....
I really really love them, they look amazing in my opinion...pretty sure I had a few people turn their heads to have a look as I drove past which, I know is vain but I loved that feeling !
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #10 on: May 21, 2015, 04:36:02 pm »
Nice look mate :)
  • -Receive: 442
« Reply #11 on: May 21, 2015, 07:04:58 pm »
Looks a lot better now and  will be even better when you lower it
Offline JD2032
« Reply #12 on: May 21, 2015, 08:37:24 pm »
Cheers Pal,
Don't really want to lower it to be honest, never been a fan!
  • -Receive: 442
« Reply #13 on: May 21, 2015, 09:44:34 pm »
know what you mean as i wasnt but then when i put the r32 alloys on then i wanted the ride height to look right,,then it was a slippery slope :signLOL:
Offline JD2032
« Reply #14 on: May 21, 2015, 09:52:40 pm »
To my eyes there is not even enough room to go lower!! I may be wrong but bah!!
I wouldn't mind some better suspension, but don't want to go any lower, is there such a way?
