Author Topic: low speed steering noise  (Read 2246 times)
dansmith180
« on: May 17, 2015, 06:38:40 pm »
Hi guys, noticed a bonging noise when steering at low speed mostly when manuvouring even on small turns not just full lock, doesn't seem to be from one side specifically. Not noticed anything else wrong just wondering what the most common issues are that cause this? What should I check first? Cheers.
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: low speed steering noise
« Reply #1 on: May 17, 2015, 07:51:54 pm »
Springs or topmounts possibly.
I seem to be getting a similar thing, a few quiet 'pops' when parking. It doesn't really concern me, but I'll keep an eye (ear) on it. I probably should have replaced the topmounts when I got the H&R springs fitted.
dansmith180
« Reply #2 on: May 17, 2015, 08:12:10 pm »
Cheers mate, I thought it could be top mounts since they're the original and I had the KW's fitted about 17k ago now. I think Silverstone may have killed them but I expected to break something.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #3 on: May 17, 2015, 08:35:46 pm »
Give us an update when you sort it, it'll give me an idea if/when mine gets worse!
dansmith180
« Reply #4 on: May 17, 2015, 08:40:27 pm »
Will do mate
Offline gazrn
« Reply #5 on: May 18, 2015, 11:13:10 pm »
I had similar and changed top mounts for RS3 mounts seems to have cured the issue  :happy2:
dansmith180
« Reply #6 on: May 19, 2015, 01:58:24 pm »
I've heard about that upgrade? Do you know what the part numbers are? What's the advantage of the RS3 ones? Thanks
Offline gazrn
« Reply #7 on: May 19, 2015, 03:40:53 pm »
Part No's are as follows
8J0 412 331 - Strut Mount x2
6N0 412 249 C - Bearing x2
N 910 216 01 - Nut x2
N 101 277 07 - Bolt x6
they seem to be heavier duty than the standard GTI Mounts with stiffer rubber so should be more durable, I have my motor lowered and it killed my standard mounts hence the reason for the upgrade.
dansmith180
« Reply #8 on: May 19, 2015, 04:26:45 pm »
Thanks, I'll look into it  :happy2:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #9 on: May 19, 2015, 05:17:58 pm »
I've ordered those strut mounts for my Eddie that will get fitted with the rest of the new parts. Just the strut mount is uprated, the rest are the same parts the GTI already has.
I also got new bearings and shorter bumpstops (since the suspension is lowered).
