Author Topic: Help - Knocking noise  (Read 1062 times)
Offline Joe Hryszko
« on: May 20, 2015, 02:46:24 pm »
Hi guys,
Only owned my Mk5 Golf Gti for 3 nearly 4 weeks now and after the initial excitement phase, I have noticed a very slight knocking noise coming from what sounds like the front left side suspension (i think?) The noise doesnt happen when just driving along, it only happens when I accelerate and let off in low gears, for example 1st gear, accelerate a little bit, let off the pedal but dont change gear and it will make a knock/thud sound! Anyone able to shed some light on what this could be?
Also when sat stationary with the engine on, when i wiggle the steering wheel there is again a slight knocking noise from the same side (front left side) wheel.
Any help, much appreciated!
Offline Mana321
Re: Help - Knocking noise
« Reply #1 on: May 20, 2015, 03:36:22 pm »
Mate check your gearbox mount (dogbone) i had the same issue changed mine a couple of weeks ago and now the noise is gone :happy2:
APR Stage 2+ FK Coilovers, Forge Twincooler, Evoms CAI, Rev D dv, Longlife 3" Turboback Exhaust, Loba HPFP, ECS Tuning Dogbone Mount Insert
Offline Joe Hryszko
« Reply #2 on: May 20, 2015, 04:51:16 pm »
Ahhhh perfect, easy to change? Thanks mate!! :D
