Author Topic: Damper to match to VWR springs?  (Read 10656 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Damper to match to VWR springs?
« Reply #15 on: May 06, 2016, 03:02:35 pm »
Cool, thanks for the follow up!   So you've got the MK5 flavour B8s with VWR springs.   My local roads are pretty terrible too so I'm thinking of trying the new VWR dampers + springs combo.  I like the idea of a bit less roll and tightening things up, but really don't want it any crashier than it already is  :smiley:
For less roll the ARB are much more important than the dampers and springs, I think, although stiffer springs will help to reduce body roll.
I'd recommend VWR+B8 dampers for mk6 with H&R ARB 26/22 mm or Eibach Pro-Kit+Koni FSD with H&R ARB 26/22 mm (soft setting at the front and stiff setting at the rear). Either option will please you, I think.
I highly doubt you'll find comfier sport springs than Eibach Pro-Kit, though.
« Reply #16 on: May 06, 2016, 03:20:50 pm »
Thanks for that, again  :smiley:
Would these be the right Eibach springs? - http://www.eibachshop.co.uk/eibach-prokit-performance-spring-kit-e10850140622_p31224005.htm?gclid=COjm86jSxcwCFesW0wodtXcLqQ#.Vyyn6mz2ZaQ
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #17 on: May 06, 2016, 08:21:00 pm »
Well, the Eibach Pro-Kit springs for GTI are only sold for American cars. The correct part number is 85100.140. That should work too, although I don't know the difference between the one from the link and the American version.
« Reply #18 on: May 09, 2016, 09:43:08 am »
OK thanks!  They would have to be imported then as I can't find a UK supplier!
Offline markjj
« Reply #19 on: December 10, 2016, 03:21:35 pm »
Hi any update on the vwr springs + dampers combo. Been looking to buy this set up?
Offline colesey
  • -Receive: 89
« Reply #20 on: December 10, 2016, 05:23:25 pm »
I have had this combo since summer and it works nicely. The ride is pretty much as stock, with the moderate lowering and rebalancing giving better turn in and overall handling. Is a good OEM+ solution.
Offline shoaybmakda
  • -Receive: 54
« Reply #21 on: December 12, 2016, 01:43:05 pm »
@colesey did you have different shocks? Or oem shocks? As I'm tempted to get the VWR springs only but not sure if it will make the ride harsh on standard shocks
« Reply #22 on: December 12, 2016, 01:52:26 pm »
I believe he has the full kit, which is around the £500 mark.   The standard dampers are pretty harsh, but the springs feel about right for my tastes.  Any stiffer and it'll be in Civic Type R territory!
Offline colesey
  • -Receive: 89
« Reply #23 on: December 12, 2016, 04:18:40 pm »
Yes, it is the full VWR dampers plus springs combo that I have.
Offline markjj
« Reply #24 on: December 17, 2016, 02:10:38 pm »
Found an online quote of £520 delivered  for the combo. May have to order a set after Christmas here's the link.
https://vwpartsinternational.com/shop/vw-racing/shock-absorbers-kits/vw-golf-mk5-vwr-sport-shock-absorber-spring-kit-volkswagen-racing/
Offline bonelorry
  • -Given: 72
  • -Receive: 44
« Reply #25 on: December 17, 2016, 03:25:10 pm »
You have just missed out mate, Awesome GTI had a 12 days of Christmas Sale on VWR products and last Weekend the Dampers and Springs had 20% off.
I got the Dampers and Springs for £412!
Offline markjj
« Reply #26 on: December 18, 2016, 09:08:24 am »
 I would of got them for that as well  :doh: :doh: hopefully they'll have some New Years sales. I'll keep an eye out this time.
