Author Topic: Orbital Polisher Newbie  (Read 14976 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=um438ncdh0dgip9b75n4t44uhh&/topic,90967.msg917089.html#msg917089
Re: Orbital Polisher Newbie
« Reply #15 on: June 25, 2015, 02:27:46 pm »
Thanks dan. I have seen the VRG for £281.40 delivered. Just the machine/backing plate. So i'm leaning towards that at the moment. Its a pity none of the pads i have will work on these bigger machines.
05 | Tornado Red | DSG
dansmith180
« Reply #16 on: June 25, 2015, 02:51:23 pm »
Wow that's a really good price, just spoke to my boss and he said we can't match that so I'd go for it. Even after buying a couple of pads and compounds its £100 odd less than the Rupes. Like I said I've heard good stuff and know for a fact their rotary machines are really good so I reckon you'll get some good results.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #17 on: June 25, 2015, 03:16:07 pm »
I will add it to my wishlist i found one on eBay for £259.17 delivered. Euro sellers are doing a bit better these days as the euro is weak. Can u recommend a good set of pads and some polish for this?
What i have at the moment.
Chemical Guys V36, V34, V32
Dodo Juice Supernatural Micro Prime
dodo juice lime prime
Offline xjay1337
  • -Receive: 377
« Reply #18 on: June 25, 2015, 04:21:32 pm »
Good machines.
They are forced drive dual action polishers.
I personally prefer a rotary,  we use flex pe14-2-150s
Rupes are good and so are those flex vrgs
 The rupes are random orbital da which will slow down or stop spinning if you angle it as such.  They have a bigger throw which is good for larger panels.  Annoying on smaller ones. Id get the flex vrg personally but i think dan rates the rupes very highly  :) he uses them a lot more , ive never used a rupes myself.
Thanks mate will i see better results than with the das 6?
Yes mate with either a rupes or a flex vrg you will get better results with a das6 pro. Which arent bad machines just quite vibratey.
dansmith180
« Reply #19 on: June 25, 2015, 06:38:17 pm »
I would recommend starting with a green hexlogic pad (heavy cutting) and some Rupes UHS polish.
Then finish off with a black hexlogic pad (finishing) and some Sonax profiline perfect finish.
With the UHS makes sure its thouroughly spread otherwise it can fling a bit especially on curved panels but it doesn't dust because its more watery. With the Sonax its goes a long way so you don't need much and you will go through a few cloths buffing it off because its quite thick and taccy but does an excellent job so its worth it.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #20 on: September 08, 2015, 05:03:01 pm »
I didn't get around to buying the new polisher yet. Its on my rather long wanted list.
Went camping for the weekend and had some rather nasty bird poo spots on the car. Got them off as soon as i got home but one of them has marked the paint at certain angles i can see where the bird poo was. Also a lot of water spots are developing. I apply wax or sealant every few weeks so surely this should stop the bird poo/watermarks??
Any protection products you guys can recommend for the higher temps over here?
Offline xjay1337
  • -Receive: 377
« Reply #21 on: September 09, 2015, 11:20:16 am »
CQUK...
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #22 on: October 22, 2015, 03:12:40 pm »
Can someone point me in the right direction for pads for the FLEX XC 3401 VRG Positive Drive Orbital Polisher.
I bought the wrong size lol
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #23 on: October 22, 2015, 04:59:34 pm »
Checking the specs
Velcro pad   150 mm or 5.9 inches
I bought two 6 inch pads and they are two small.  :sad1:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #24 on: October 23, 2015, 08:44:37 am »
I contacted the seller i bought the pads from they can exchange for Rupes 180mm pads.
Will these be ok or should i get a refund? @dansmith180
dansmith180
« Reply #25 on: October 23, 2015, 07:51:19 pm »
I think the problem is the face on those pads will be 6" but the backing part is 5". Same with the Rupes pads as they're a cone shape so a 6" pad has a 5" backing and the 7" has a 6" backing.
The 180mm rupes pads should be fine but i would look at the Lake Country 6.5" pads as they're more similar to what you've purchased and there's more to choose from.
Sorry I only just replied, although you tagged me I wasn't notified I just happened to look
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #26 on: October 23, 2015, 09:05:00 pm »
Thanks mate i will back these and have a look at the others you mentioned.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #27 on: November 11, 2015, 11:13:43 pm »
@dansmith180 i now have Rupes UHS and Sonax profiline perfect finish.
Just not sure on what Lake Country pads to get.
I'm also looking for a new wax i've been using dodo juice supernatural wax. Thinking maybe a liquid that i can apply with the polisher?
dansmith180
« Reply #28 on: November 11, 2015, 11:32:17 pm »
I would use a yellow one with the UHS and a black one with the Sonax. Wax wise it depends what you want,, if you're after gloss then machine applicated sealants such as Wolfgang deep gloss paint sealant and Chemical guys Blacklight are fantastic. If you're after longevity however they're not great really, I would stick with Bilt Hamber speed wax or any Collinite wax
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #29 on: November 12, 2015, 11:09:38 am »
Thanks again mate. Whats what should i use to remove the wax with a polisher?
