Author Topic: Orbital Polisher Newbie  (Read 14732 times)
Offline Daveyboy
  • -Given: 46
Re: Orbital Polisher Newbie
« Reply #60 on: December 17, 2015, 01:28:25 pm »
Course it would. Have faith in das auto lol
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=o83s7qpaaab1pp6bgdpf8if08h&/topic,90967.msg917089.html#msg917089
« Reply #61 on: December 21, 2015, 06:25:14 pm »
Not getting on to well with this. Even with the new polisher/polish. Swirls come out easy but scratches that don't even look that deep will not come out.
Am i doing something wrong? I've tried the spot microfiber pad, 5.5 inch corduroy cutting pad, Yellow 6.5 inch pad and the yellow 5.5 inch pad. Had enough now.  :sad1:
05 | Tornado Red | DSG
dansmith180
« Reply #62 on: December 22, 2015, 12:58:05 am »
That seems odd.
What size sections are you doing? For instance how many sectors do you split the bonnet into?
How many times do you go over said area before you buff off the polish?
From a scale of 1-10 (one being snails pace and ten being after 7 red bulls speed) how quickly do you move the polisher from side to side/ up and down?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #63 on: December 22, 2015, 07:59:50 am »
I did the bonnet is 6 sections.
6/8 passes before buffing off. Moving the machine slowly hence working on this for over a week.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #64 on: December 22, 2015, 01:48:37 pm »
Given up on that panel. TBH once i got the scratch on the bonnet cleaned up. I should have just given it the once over with the sonax and a black pad. The scratches that have always been there don't seem to want to budge.
The black 6.5 inch Lake County css pad works really well with the sonax. Tried the 5.5 inch black hex logic pad and it was pants in comparison. Will be ordering some Lake Country 5.5 inch pads for my next polishing session.
dansmith180
« Reply #65 on: December 22, 2015, 05:19:31 pm »
I'm stumped as to why you're having that issue tbh, the paint is hard but with how you're doing it and what you're using it should be coming up pretty nicely.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #66 on: December 22, 2015, 06:27:50 pm »
This session has cleaned most things up nicely maybe the scratches i'm chasing are just too deep. When i check with the lamp some areas are perfect. I have a few random deep scratches here and there.
I spent the most time on the drivers side rear wheel arch. Just above the curve of the arch a lot of scratches they would not budge. The drivers door has been painted so maybe this was damaged the same time.
I think polishing a car that had bad paint in the first place would give me more satisfaction. The two polishing sessions i've done with the das 6 over the past year and a half actually did a ok job.
Here is the roof i just did one pass with the sonax and black pad. There are 3 random scratches on the roof which i would have liked to get out but didn't even try as i've had enough. Maybe i need a really hard spot pad for the das 6.
Waxed her with collinite insulator wax.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #67 on: December 26, 2015, 01:01:39 am »
Took the car out yesterday. Definitely an improvement over my last attempts. It's not so sunny now so i don't notice the deeper scratches. Thanks again for all your help.
Although the car is in good condition compared to most Spanish cars Ideally nearly half of it needs a respray due to stone chips and dodgy touchups in the past.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #68 on: February 01, 2016, 01:30:14 pm »
Gave the car its first wash since the polishing session. I don't know why i bother its already swirled/scratched up mainly on the passenger side, i suspect it the kids.  :fighting:
Tried the bilt hamber double speed-wax did not get on to well with that its not easy to buff off.
