Author Topic: Removing stains from steering wheel  (Read 1873 times)
Offline oak_grun
« on: May 25, 2015, 02:56:03 pm »
Hi, what's the best way to clean a leather steering wheel? I've tried leather wipes just now and the section of the wheel looks worse! I think it's other half make up tbh, not that she has admitted it! Lol..
Really annoying? Don't want to ruin or make it any worse?
Any ideas, hints or tips guys and gals?
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Removing stains from steering wheel
« Reply #1 on: May 25, 2015, 02:59:46 pm »
Unfortunately they're difficult to bring back and is just the leather wearing more than likely.
I saw a thing a while back on wrapping a warm damp towel around the wheel to soften the leather. Clean vigorously and then seal again but I never tried it so can't speak from experience.
I've also seen some people say that you should use leather conditioner on the wheel because it's a different type of leather.
I personally clean the crap out of it with leather wipes and damp microfiber and then re-condition once every few months and mine looks great.
Offline Washout
« Reply #2 on: May 25, 2015, 03:20:04 pm »
Not sure how well it would work on the wheel, worth a try. I'm going to get a couple for cleaning inside my car.
http://www.ebay.co.uk/itm/JML-Doktor-Power-Magic-Eraser-Stain-Remover-Sponge-Cleaning-Block-/360963683689?pt=LH_DefaultDomain_3&hash=item540b1cb569
Offline Horatio
  • -Receive: 39
« Reply #3 on: May 25, 2015, 04:54:19 pm »
This stuff is really abbrasive and will remove the protective clear coat and remove the dye from your leather, as with plastics.
Offline cpk
« Reply #4 on: May 25, 2015, 06:54:37 pm »
I bought a wheel from someone off the site, and although it was in pretty good nick, I'm fussy, so did some investigation and thought I'd give this a try:
http://www.leatherrepaircompany.com/store/#!/Leather-Steering-Wheel-&-Gear-Shift-Repair-Kit/p/11581055
Took a bit of time and effort, but the results are pretty amazing.  There were deep scratches - not far off rips - and they're no long visible.
(I got carried away, and restored the VW badge in the middle with Autosol - make sure you cover the black sections if you go this far.)
Edition 30 - Reflex Silver - No. 1741.  Revo Stage 1, Forge DV, Sachs clutch, SuperPro Anti-Lift Kit, Pioneer AVH-8400BT, GoPoint and DashCommand.
Offline andybon
« Reply #5 on: May 25, 2015, 08:01:39 pm »
I just use wet wipes once a week, comes up great.
How hard can it be?
Offline DrG_GTi
« Reply #6 on: May 28, 2015, 10:50:43 pm »
I used the exact same kit as cpk, although my mfsw was in poor condition so needed a restore. It does take a little work and you need to apply the paint and top coat thinly and dry with a heat source,  just use the matt coat, but it all worked a treat and comes up as new. I may have made it a bit black compared to oem but I'd rather that than too grey, so never mixed any white in!
