Author Topic: Going for stage1 custom map. what to do before map?  (Read 5240 times)
Offline K9
  • VW LifeStyle
« on: May 25, 2015, 10:04:56 pm »
hey. i'm booked in for a stg1 custom map on Rototesters. The car is a gti AXX with 53k miles on it and a fresh cambelt with waterpump from vw. 200miles ago. Ordered a Rev.G DV from a member of here and checked the dipstick test and oil cap test and the car went nuts when i opened the oil cap  :rolleye: anything else that i need to chec/do before rototest and map? will be dricing with shell V-power. Should i put a full tank v-power and injection cleaner?
Offline PT82
  • -Given: 19
Re: Going for stage1 custom map. what to do before map?
« Reply #1 on: May 25, 2015, 10:23:32 pm »
Cam follower and budget for a new clutch in future if manual.
dansmith180
« Reply #2 on: May 25, 2015, 10:52:43 pm »
As above do a can follower, would also be good to do precat removal and panel filter to gain a few extra cheap horse powers.
If you use injection cleaner then it's a good idea to do an oil change not too long afterwards as well.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #3 on: May 25, 2015, 10:54:55 pm »
Defo do a Cam follower inspection if you haven't already...
PCV "seems" ok
Your clutch may slip, as said above, if so ask them to dial it back a tad, torque is fun but it destroys clutches and tyres (if not linear).
Don't do the injection cleaner this time imo, unless as above your dropping the oil... but do a few half tanks of vPower if you don't usually use it; and have enough fuel for the mapping.
Most of all, have fun on your return journey/s ;)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=7t4n90oup3fnlfl1p555se7hpi&/topic,19740.0.html
« Reply #4 on: May 25, 2015, 10:59:56 pm »
Injector cleaner doesn't require and oil drop afterwards... At least the bg44k doesnt
dansmith180
« Reply #5 on: May 25, 2015, 11:13:46 pm »
After doing some reading I changed mine after BG44K, to be fair it had been 5K so I was planning on it anyway.
Offline rashg60
  • -Receive: 41
« Reply #6 on: May 25, 2015, 11:14:07 pm »
I'm also booked in for a stage 1 remap in the next couple of weeks - no one told me about a clutch???
Would this need to be replaced soon after the remap? Are any other parts affected by the remap and need changing?
I've got a completely standard 2006 manual gti at present and was only thinking about doing the stage 1 remap to give it some extra power. I'm slightly hesitant now.....help!
Previous motors (in order of succession since 1994):-
VW Golf MK2 GTi 8v
Peugeot 205 1.9 GTi
VW Corrado G60 Supercharged
Volvo C70 2.0 Turbo Convertible
Audi TT MK1 1.8T quattro (225)
Mercedes CLS 320 V6
Audi TT MK1 3.2 V6 Quattro
Audi A4 Convertible 1.8T Quattro
VW Golf MK5 GTi 2.0 Turbo
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #7 on: May 25, 2015, 11:17:10 pm »
Depends on the torque... don't go crazy with it and you'll be fine. :happy2: under 300lb-ft with a nice curve "should" be ok, but it really depends on how much life is left in your 10 year old clutch!?
Offline rashg60
  • -Receive: 41
« Reply #8 on: May 25, 2015, 11:32:18 pm »
If it does need replacing, what would be recommended?
What do people normally go for and what works well with the Stage 1 remap?
VW Golf MK2 GTi 8v
Peugeot 205 1.9 GTi
Mercedes CLS 320 V6
dansmith180
« Reply #9 on: May 25, 2015, 11:36:11 pm »
Helix organic clutch with new OEM DMF. As above with a good linear map it should be fine on stage 1 but you never know, some go with 40k miles stage 1 and some are fine with 100k stage 2+, it's a risk but at stage 1 it's a small one.
Offline K9
  • VW LifeStyle
« Reply #10 on: May 26, 2015, 06:49:18 am »
How about when i have a dsg gearbox? Got LC as standard. And i made a oil change let's say about 1000km 5w40 and i never filled my tank with 95. 98. Always shell v-power. So i injection cleaner wont help anything. And the cam follower, is it okay if i change it after mapping? @Scottymon
Writen with my fingers
« Last Edit: May 26, 2015, 04:04:37 pm by K9 »
Offline Scottymon
  • -Given: 83
  • -Receive: 125
« Reply #11 on: May 26, 2015, 08:47:50 pm »
^ Sure, however your tuner will probably do it for you if you ask. :thumbs
Offline K9
  • VW LifeStyle
« Reply #12 on: May 26, 2015, 11:25:42 pm »
Whats the max. Torque i can take out from the factory dsg software? He told me i would get like 425nm and 250-260hp
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #13 on: May 27, 2015, 11:42:58 am »
Replace the fuel filter as well. Its under the rear sill on driver side. not noramally a servicable item but they do get clogged up. go for the 6.6bar version  :happy2:
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #14 on: May 27, 2015, 12:22:01 pm »
What's the part number of the 6.6 bar fuel filter?
