Author Topic: Part number for DAB and GPS cables?  (Read 3244 times)
Offline STV4R
« on: May 27, 2015, 01:11:20 pm »
Hi, Im in need of the part numbers for DAB and GPS extension cable to go from the sharfin to my RNS510 if anyone has them?
Steve
Offline SI-R32
  • -Receive: 126
Re: Part number for DAB and GPS cables?
« Reply #1 on: May 27, 2015, 02:29:59 pm »
Just go on eBay and get some generic ones,  quite expensive from vw for 5m ones
If your defo after vw ones I can look up part numbers when next to PC later
Offline STV4R
« Reply #2 on: May 27, 2015, 03:11:47 pm »
Ive looked on ebay but cant find any DAB, can only find GPS
Offline SI-R32
  • -Receive: 126
« Reply #3 on: May 27, 2015, 03:24:18 pm »
Ah well,  if you just put in 5m fakra then the generic ones come up with light green end,  GPS blue,  dab back,  the light green will fit both as its generic and the cable will be fine for dab and GPS, fyi vw use the same standard cable for any aerial connection,  appreciate not vw on eBay but cable will be fine
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #4 on: May 27, 2015, 06:00:03 pm »
Hi, this is the exact cable I used, depending on your cable routing it might be worth requesting 5m or 5.5m length from the seller but you can always curl up some behind c-pillar
http://www.ebay.co.uk/itm/Antenna-extension-cable-FAKRA-female-code-A-FAKRA-female-code-A-black-6-meter-/151579891011
You can also use a universal fakra cable  :happy2:
Offline STV4R
Offline fletch-
« Reply #6 on: July 10, 2015, 02:02:22 pm »
Has anyone got the part number for the dab roof aerial? Thanks
