Author Topic: Brakes on the Beater. Seat Alhambra 98  (Read 27359 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=q6qt67i7us1qfdev2dfp9c61ct&/topic,90967.msg917089.html#msg917089
Re: Brakes on the Beater. Seat Alhambra 98
« Reply #45 on: February 08, 2016, 08:12:22 am »
Excellent job mate,si should of popped over and give you a hand and have a hol at the same time :signLOL:
That would have been nice. I'm sure i can find something else that needs fixing.
05 | Tornado Red | DSG
Offline doylebros
« Reply #46 on: February 13, 2016, 08:41:43 pm »
After a massive effort today its all finished. I also replaced both inner cv boots and the ARB drop links.
Gear changes are smooth with a nice high biting point.
Don't work on a car if you are tired i went for a test spin around the block. When i got back i remembered the wheel nut bolts and main drive shaft bolts were only hand tight. I forgot about it after filling the transmission. muppet.
Your ability to do these types of jobs,knowing your more an upstairs use your brain type of guy amazes me, 10 out 10 for your ability and persistance to succeed were many others would of given up.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #47 on: February 13, 2016, 08:50:50 pm »
Thanks mate i enjoy it, and it gets me off the computer.
On to my next problem now. She struggles to start in the morning so ordered the correct size battery some muppet sold me the wrong battery a few years back (before i took on the maintenance myself).
Bought one of these http://www.bateriaprofesional.es/es/baterias-de-arranque/50-bateria-varta-h3-100ah-silver-dynamic-830a-12v.html
Went to check the glow plugs but the harness just disintegrated in my hand. So i've ordered a new one from the stealers.  :sick:
Did manage to check one plug with the multimeter and it returned 0.4 so will replace all the plugs also as i read they should have a resistance around 1.
Offline doylebros
« Reply #48 on: February 13, 2016, 08:59:41 pm »
I find the MKIV. Golf glow plug harnesses have to be changed if you've got a heater plug problem - they just go brittle.
When testing the glow plugs institute I just use a fused feed and a series amp meter - I find this a more simplistic way to prove which glow plugs are faulty or if I have an earth return fault for what ever reason.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #49 on: February 15, 2016, 04:59:58 pm »
I'm getting a judder when pulling off in first. It did exactly the same prior to changing the dmf/clutch.
At first i thought it would go away when i get used to the new biting point but i'm not so sure.
Any thoughts on this? Only does it when cold (14ยบ here today).
Offline doylebros
« Reply #50 on: February 15, 2016, 05:05:08 pm »
Did you do a good good of degreasing the pressure plate and flywheel surfaces on the rebuild Dazza?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #51 on: February 15, 2016, 05:16:05 pm »
No i replaced everything. Gave the bell housing a good clean though.
Offline doylebros
« Reply #52 on: February 15, 2016, 05:23:52 pm »
Even if everything is new it still needs the degreaser removed from those faces - there protected to prevent rusting in storage.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #53 on: February 15, 2016, 05:53:05 pm »
:ashamed: The clutch/dmf was also preassembled so don't know how luk expect you to clean it  :confused:
Offline doylebros
« Reply #54 on: February 15, 2016, 05:55:39 pm »
What can I say - did the fitting instructions ask for them to be cleaned?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #55 on: February 15, 2016, 06:04:13 pm »
Instructions  :scared: I just bolted it down. There were no instructions.
Do you think it will settle down over time? Only done 20/30 km so far.
Offline doylebros
« Reply #56 on: February 15, 2016, 06:13:17 pm »
I hope so cause I can't see whatelse you could of done - my next move would be rebleed and at least 500k driving and monitoring - my last choice would be removal.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #57 on: February 15, 2016, 06:38:43 pm »
Id be a bit more bothered if it didnt do this before i changed the clutch/dmf. TBH the clutch and dmf looked ok it was only the slave which was fooked.
I think i did a good job. Will keep an eye on it.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #58 on: February 16, 2016, 08:19:56 am »
Car started perfectly this morning after changing the battery, glow plugs and glow plug harness. Didn't get the Judder either.  :jumping:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #59 on: February 16, 2016, 09:30:19 am »
 :pomppomp:
Nice work buddy!  :congrats:
