Author Topic: vcds vacuum leak help  (Read 1706 times)
Offline jakex181
« on: May 29, 2015, 04:20:20 pm »
Have done some testing today using VCDS, here is what i have found:
I first cleared fault codes, and set vcds to measure blocks 32 and 33, i then started the engine.
After about a minute of nothing happening the values begin to change, block 33 (lambda control) shoots up to 27% and then steadily reduces as block 33 (Lambda regulation) increases until eventually block 33 is at 0.8% and block 32 is at 4.5%. Im guessing this means i have a vacuum leak somewhere? What is the reason for the initially lag?
Re: vcds vacuum leak help
« Reply #1 on: May 29, 2015, 04:54:59 pm »
Block 32 is the long term trims for idle and part throttle.   33 must be the live adjustment.   You need to look at 32 after say, a week's worth of driving.  Mine are 0.8% and 2% respectively.  4.5 is kinda high, but if you cleared it before the test, then the initial entries will be, hence it should be treated as a rolling average only.
Did you start it from cold, or hot?   The wideband lambda takes about 60 seconds to heat up, hence the lag.
A leaking brake servo is common on the MK5.  Any hissing noises from the pedal area, which goes when you press the brake pedal?
Offline jakex181
« Reply #2 on: May 29, 2015, 05:41:57 pm »
SOLVED: it was the break servo feed
split at both ends, i replaced it with some flexible rubber pipe as its all i had so will get an order the rigid vacuum pipe. Also tested again with VCDS and block 32 showed no fuel trims so no other leaks.
Offline da_ansa
« Reply #3 on: June 28, 2015, 09:43:58 pm »
was it a hard job to change out the brake servo feed?
