Author Topic: Top mounts  (Read 8633 times)
Offline M4T VW
Re: Top mounts
« Reply #15 on: March 27, 2016, 09:21:21 am »
Haha. Thankfully I have access to lots of tools on a daily basis. Laser, CNC etc so I made lots of custom bits for my Mk2 golf. I also have a scanner that scans parts in and I can replicate them. When I remove the door cards I will be scanning the profile of them so I can make lightweight new ones  :happy2:
Re: Top mounts
« Reply #16 on: March 27, 2016, 09:42:09 am »
Like a farah arm? :D
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=f02167uqkhtf553777iurg0dt3&/topic,19740.0.html
Re: Top mounts
« Reply #17 on: March 27, 2016, 09:43:52 am »
Where are you based Matt??
Offline M4T VW
Re: Top mounts
« Reply #18 on: March 27, 2016, 03:13:17 pm »
A FARO arm yes, Not like the runner  :grin:
I'm south of Bristol Rich
Re: Top mounts
« Reply #19 on: March 27, 2016, 04:05:19 pm »
Same thing, different haircut haha
Re: Top mounts
« Reply #20 on: January 24, 2017, 02:58:46 pm »
Sorry for bumping, but are the bearings in the Ground Control mounts spherical or OEM balls?  It's hard to tell in the pics?  If the former, how long to the bearings last?
Re: Top mounts
« Reply #21 on: January 24, 2017, 09:44:00 pm »
I would presume its a thrust type ball bearing setup..... just a guess tho. Speak to @vRSAlex  he will know.
Re: Top mounts
« Reply #22 on: January 25, 2017, 10:41:35 am »
Cheers, will do  :smiley:
Offline vRSAlex
  • -Receive: 253
Re: Top mounts
« Reply #23 on: February 07, 2017, 09:56:33 am »
@Pudding they use two sets of bearings.  The spherical in the centre holds the damper rod, the outer bearing holds the spring.  The outer is an oem BMW bearing.
I'm 5 years into mine and no issues at all.
Follow AKS tuning on Facebook
Re: Top mounts
« Reply #24 on: February 07, 2017, 03:56:58 pm »
Aha, gotcha.   Do the ones you stock fit the standard / VWR springs?  I notice on their website they do different options for spring diameter.
