Author Topic: Radio  (Read 529 times)
Offline boungle1
Radio
« on: June 01, 2015, 10:41:02 pm »
hi need some help
Got a mk5 gti candy White DSG 56 plate
Come with standard 300 radio looking to upgrade to better vw radio non sat nav what options is there want it to work with blue tooth got the controls on steering wheel etc
will it just plug in and work or do I need other parts
Neil young
Offline PT82
  • -Given: 19
Re: Radio
« Reply #1 on: June 01, 2015, 10:47:06 pm »
I believe an RCD510 will be what you are after if you do not want sat nav. You will need a Bluetooth kit aswell and a cable adaptor. Maybe an updated can us gateway to prevent battery drain. (You may be lucky and have the updated one anyway on a 56 plate). It will also need to be coded with vagcom.
Offline boungle1
Re: Radio
« Reply #2 on: June 01, 2015, 10:50:00 pm »
Ok thanks for that
Neil young
Offline Blackgtiman
Re: Radio
« Reply #3 on: June 02, 2015, 12:37:15 pm »
ive just done this:
rcd510 version H £225
7p6 Bluetooth £100
aerial adapter £8.50
Vacom coding - free
Can bus update - not needed for battery as I have late version K but I will need if I want to properly code the 7p6 (still works).
Really nice set up.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Radio
« Reply #4 on: June 02, 2015, 02:26:51 pm »
ive just done this:
7p6 Bluetooth £100
Vacom coding - free
Really nice set up.
You can get a Polar BT/Battery module that will prevent the battery drain and make your 7P6 Bluetooth module work fully with your steering wheel and full FIS (if you have it). Check my GTI project if you want to see pictures.
