Author Topic: Annoying sound from rear!?  (Read 1086 times)
Offline K9
  • VW LifeStyle
« on: June 06, 2015, 12:46:32 pm »
Hey. after i removed the rear coilover adjusters to get it more lowe ar the rear, i started to hear a annoying squeak sound, sounds more like dry rubber rubbing etc. when going over speedbumps or driving slowly along a un-even road ( under 15mph ? ) what can it be? annoying me so much!
Offline jhook661
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98678.0.html
Re: Annoying sound from rear!?
« Reply #1 on: June 06, 2015, 05:52:06 pm »
I'm guessing you still have the rubber support top and bottom of the spring?? itll probably be why or the rubber supports have had it perished rubber can case squeaking
Modded Golf gti CDL engine TTE420 turbo
Rtech 440bhp 429ftlb
Offline K9
  • VW LifeStyle
« Reply #2 on: June 06, 2015, 07:39:02 pm »
Os it safe to remove the bottom and top rubber? Wont the spring be moving around then :o yes i have them both
Writen with my fingers
Offline K9
  • VW LifeStyle
« Reply #3 on: June 06, 2015, 08:27:09 pm »
Should i remove the??
Offline jhook661
  • -Receive: 20
« Reply #4 on: June 06, 2015, 10:21:25 pm »
No you need them there to support the springs and reduce the noise
Offline K9
  • VW LifeStyle
« Reply #5 on: June 07, 2015, 01:06:06 am »
How can i get the annoying rubber soynd away fron the rear? I removed the top rubber.
Offline jhook661
  • -Receive: 20
« Reply #6 on: June 07, 2015, 08:17:19 am »
I would replace the rubber supports personally I've got kW's just like you and I've taken out the adjuster to but I don't have the squeaky noise like you have or something is loose !? Tighten everything up matey
Offline K9
  • VW LifeStyle
« Reply #7 on: June 07, 2015, 11:52:56 am »
part nr. for the supports? @jhook661
Offline Wash
« Reply #8 on: June 07, 2015, 12:40:42 pm »
If you removed the rubbers that's exactly what would happen. Managed to lose one of mine so picked up another from a VW breakers for a fiver.
Offline K9
  • VW LifeStyle
« Reply #9 on: June 07, 2015, 12:51:35 pm »
@Wash i removed the top support rubber and the sound still exist, i guess it's the lower rubber that goes in the arm. will it stop if replacing top and bottom with oem new rubbers?
Offline jhook661
  • -Receive: 20
« Reply #10 on: June 07, 2015, 05:25:55 pm »
You need it top and bottom mate so that noise isn't there I don't have part number unfortunately ?!
Offline K9
  • VW LifeStyle
« Reply #11 on: June 08, 2015, 07:56:45 am »
Ordered new for both sides up and down oem just to be sure. From vw they were about 22£
