Author Topic: My golf GTtdi Sport more door(for sale)  (Read 109586 times)
Re: My golf GTtdi Sport more door(for sale)
« Reply #405 on: March 25, 2012, 08:41:07 pm »
Helluva lot of work gone into some Awesome OEM++ modding.  The lucky buyer is gonna get a corker!  Wish I could afford it for SWMBO
Offline mortygttdi
  • -Receive: 146
« Reply #406 on: March 25, 2012, 10:32:53 pm »
Cheers Mike
Andy the turbo was CR's stage 2 GT1756 not sure on the part number
Darren
Offline stevw1
« Reply #407 on: April 29, 2012, 08:54:57 pm »
Such a shame to see this go Darren. Hope you have something nice tp replace it  :happy2:
Offline unitzero
« Reply #408 on: May 02, 2012, 08:56:16 pm »
such an awesome mk5 you have there mate.  wish I could afford to buy it.
Offline blade4real2004
Re: My golfs transformation...
« Reply #409 on: August 18, 2012, 01:45:08 pm »
does any body know if you can retro fit the more basic heater a/c control off the mk6 to the mk5?
Damien Its a case of buying the new climate and surround then changing some wires
This is taken from a user called NorthernSky off VWNavi
Re: Climatronic on screen
I installed the unit and work as expected (mine is VW Jetta GLI 2007 and I did not needed to wire in pararell on Conector C and B)
Parts I needed:
1K0 858 069 M 1QB Trim
5K0 907 044 BT ZJU Climatronic Unit (5K0 907 044 CB ZJU with Heater button)
1K0 907 530 AD Can Gateway ('S' revision or later might work also)
3C8 937 049 AB Power Electrical Module (For compressor to work)
Optional:
1K0 907 659 Quality Sensor (optional)
1K0 971 939 C Holder (optional)
1J0 972 483 A Quality Sensor Conector (optional)
000 979 009 E Quality Sensor Wire X2
Climatronic Wiring
On A Connector (black) extract both; Pin 16 and Pin 20 and put Pin 16 on the place were Pin 20 was, leave the wire on Pin 20 loose (not connected to the harrnes) for later connect the Air Quality Sensor if needed.
If you have an older VW Model you will need as user mogwai pointed out this wiring to change:
Motors in parallel:
On C Connector (brown): Pin 7 connected to Pin 10 and Pin 8 connected to Pin 9
On B Connector (black): Pin 6 to Pin 7
Quality Sensor Wiring (optional):
On C Connector (black):
Pin 1 from Quality Sensor to Pin 20 which we replaced by Pin 16 on Climatronic
Pin 2 from Quality Sensor is Ground to Pin 19
Pin 3 from Quality Sensor to Pin 4 on Climatronic
YOU NEED TO MAKE THIS STEPS as lala30 pointed out (My compressor did not work until I performed the 2 step):
First Step: Basic settings: hold button AC + button straight blowing (third button from left). You will see both buttons leds blinking one after another..let them run till they come to the normal status. Reference: http://www.my-gti.com/2513/volkswage...ostics-mark-vi
Second Step :Compresor Settings: Starting the engine and hold LONG-AC + heating rear window.Let it run till it comes to the normal status.
It says you need the 3C8 CECM but me personally I have a 3C0 937 049E and every thing works fine also bare in mind the surround is on back order at the moment,
Darren
Offline mortygttdi
  • -Receive: 146
« Reply #410 on: November 05, 2013, 02:05:41 am »
Hi guys I heard that my old golf had been wrote off so thought I'd put one last pic of it on here. RIP
Offline Matto
  • -Receive: 116
« Reply #411 on: November 05, 2013, 06:32:12 am »
RIP indeed. Lovely motor. Was one of my favourites.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #412 on: November 05, 2013, 07:08:02 am »
One of the best, real shame
Cluster and Key coding
Location Great Yarmouth
« Reply #413 on: November 05, 2013, 07:59:05 am »
so a shame with all the effort that you put into it Daz. Wish I got that front bumper and lightS of it
Offline woahnowboys
« Reply #414 on: November 08, 2013, 01:30:53 pm »
Such an awesome car, that's gutting :sad1:
'87 MK1 Cabby - To be 20vT'd.
MK5 Daily.
Instagram - woahnowboys
