Author Topic: Coding Mirror mk5 golf reverse  (Read 1548 times)
Kam88
« on: June 06, 2015, 10:24:55 pm »
Hi everyone i used to have a 330CI bmw and when i stuck it in reverse the mirror used to go down so you can see the kerb is this possible in mk5 without actually changing anything ? if so how ?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Coding Mirror mk5 golf reverse
« Reply #1 on: June 06, 2015, 10:36:42 pm »
There is a checkbox in vcds but depends if you have the correct module.  I think you need memory seats as well.
Iirc some cars which came with reverse sensors from factory had the dip as well,  some sort of link but not sure what it is.
Or,  get a 200 quid polar fis link which allows you to do it too.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #2 on: June 07, 2015, 11:02:36 am »
Needs the correct mirror module and a new mirror motor i think
