Author Topic: Front wheel hub bolt help  (Read 1123 times)
Offline GTI Dave 30
« on: June 07, 2015, 10:33:11 am »
Hi trying to Un do front  wheel hub bolt on edtion 30 24 mm extension bar snaped that tight using a breaker bar jump on it still not moving any help please need to get to cv boot
Offline v4rley
  • -Receive: 104
Re: Front wheel hub bolt help
« Reply #1 on: June 07, 2015, 10:43:42 am »
What length breaker you using? Guess you still got wheel on, and doing through the centre bore of the wheel?
Offline GTI Dave 30
« Reply #2 on: June 07, 2015, 10:48:54 am »
Yes car on ground 3ft breaker
Offline v4rley
  • -Receive: 104
« Reply #3 on: June 07, 2015, 10:58:26 am »
Hmm, cannot really assist much more over the net! sounds like you got the tools for the job. What type of bolt is in there as theres a 6 sided and a 12 sided? My next option would be a bigger bar I guess, or extend the one you got although your not meant to  :evilgrin:
Hopefully someone with a bit more experience will be along  :happy2:
Offline GTI Dave 30
« Reply #4 on: June 07, 2015, 11:07:03 am »
12 sided
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #5 on: June 07, 2015, 11:08:13 am »
Ideally you'll need a 3/4" impact socket and a 1M 3/4" breaker bar to do it by hand, they are tight as hell and most likely a bit corroded too. Or with wheel off ground get someone to press brake pedal and undo with impact gun
Offline GTI Dave 30
« Reply #6 on: June 07, 2015, 12:35:04 pm »
