Author Topic: Airbag Light  (Read 506 times)
Offline SeyiiOluwa
Airbag Light
« on: June 07, 2015, 11:50:55 am »
Hey guys, I've seen a few threads on here but I don't know what I should try. I was fiddling about with the cables under the seat and I took out a plug which tripped the airbag light. I put it back in and the airbag light stayed on. Plugged in a computer and it showed 'NO FAULT' and when you clear it the light comes back after a ew minutes. Tried disconnecting the battery for 20 minutes as I had read that somewhere but that still didn't work.
Any other quick/easy fixes? Will I have to cut and resolver my loom?
Thanks guys
Kam88
Re: Airbag Light
« Reply #1 on: June 07, 2015, 01:55:02 pm »
double check make sure you connector is actually connected ?? have you got a vag com ?
Offline th3_f15t
  • -Receive: 183
Re: Airbag Light
« Reply #2 on: June 07, 2015, 02:17:49 pm »
Also check you haven't damaged the wiring under the seat while playing around.
Offline SeyiiOluwa
Re: Airbag Light
« Reply #3 on: June 08, 2015, 06:15:10 pm »
Apparently there was a high voltage sent to the drivers side airbag, I'm guessing this happened recently......
Getting it sorted next week
