Author Topic: PCV  (Read 1530 times)
Offline samiul11
PCV
« on: June 09, 2015, 10:05:33 pm »
Right guys im about to order a new PCV part number 06F 129 101 R and the pcv rubber gasket 06F 103 483 E.
My question is, is this all i need to change to the latest PCV? I've read up that a new check valve is needed too?
Any advice would be appreciated  :drinking:
Offline Washout
Re: PCV
« Reply #1 on: June 09, 2015, 10:29:05 pm »
I was looking at this to replace mine, not sure now as the revised part doesn't match the one you listed.
http://www.psituning.com/product.php/21395/oem_pcv_breather_update_kit___2_0tfsi
Kam88
Re: PCV
« Reply #2 on: June 09, 2015, 10:30:56 pm »
Yes that and gasket is what i just replaced 2 minutes to replace it
Offline samiul11
Re: PCV
« Reply #3 on: June 09, 2015, 10:32:42 pm »
So i wont need the breather pipe with the internal check valve?
Kam88
Re: PCV
« Reply #4 on: June 09, 2015, 10:39:36 pm »
i never replaced it unless it is physically damaged then i wouldn't no
Offline samiul11
Re: PCV
« Reply #5 on: June 09, 2015, 11:00:22 pm »
I've read that the car runs rough if the latest pcv is installed but not the breather pipe? So confusing  :rolleye:
Kam88
Re: PCV
« Reply #6 on: June 09, 2015, 11:04:56 pm »
i fitted it and car runs sweet i did do my diverter valve at same time
Offline samiul11
Re: PCV
« Reply #7 on: June 10, 2015, 03:23:26 pm »
Anybody got the part number for the breather pipe?
Offline doylebros
