Author Topic: Flapper mod thingymajig on a r36?  (Read 12677 times)
Offline Aparoon
« on: December 10, 2009, 05:44:50 pm »
Can you do this on a r36 and how? Cheers  :happy2:
Edition 30 DSG, Revo 2+,BSH Intake, Autotech hpfp, Blueflame TBE,  Eibach Sportlines, Speedline Turini's GONE
Offline jonnyc
  • Herrooooo!
Re: Flapper mod thingymajig on a r36?
« Reply #1 on: December 10, 2009, 05:55:08 pm »
Remove the vacuum line from the actuator on the exhaust, and block off the line with a screw (or something sutible) to seal it up, and thats it..
Same for all vacuum operated actuators..
Offline Aparoon
« Reply #2 on: December 10, 2009, 06:10:15 pm »
Good man cheers  :happy2:
Offline candy turbo
« Reply #3 on: December 10, 2009, 06:42:44 pm »
i ve just blanked mine off with fitting the milltek , what does this thing do ???
Offline jonnyc
  • Herrooooo!
« Reply #4 on: December 10, 2009, 06:44:40 pm »
Opens up a different route for the exhaust gas to exit in the rear box.. Just makes it 'sporty' over certain RPM's..
« Reply #5 on: December 10, 2009, 06:46:58 pm »
its a diaphragm that controls the noise levels of the exhaust at certain revs to abide by EU regulations, quite at low revs, open and louder at higher revs
disabling the diaphragm (flapper) by removing the vacuum hose, tie it or fold it and zip tie it up onto the bodywork. then as said just block the hole thats left so its airtight
ive done this for loads of people on their .:R32's - in fact if i dig into photobucket deep enough i might still have the step by step photo guide i did for it if you want it?
Offline Jules86
  • -Receive: 46
    • Forumwars
« Reply #6 on: December 11, 2009, 11:13:46 am »
Pull the black tube out like so
Simply plug it with a screw or strong tape and away you go. Sounds awesome at low spee
Offline animal
  • .:R32
« Reply #7 on: December 11, 2009, 11:33:17 am »
Jonny, I'm in no way disputing what you are saying as I know nothing about the system but, it does seem odd the that actuator is after the silencer, not before it?
Also, are we just assuming that the R36 uses an identical set-up?
Offline Jules86
  • -Receive: 46
    • Forumwars
« Reply #8 on: December 11, 2009, 11:35:19 am »
Yep. AFAIK it just has a different manifold but same back set up.
I think it just simply lets the 'sound' out of one tailpipe and not both at low revs which you can change by blocking it.
Makes a huge difference, the missus thought it was 'ridiculous' as we drove through reagent street last week  :signLOL:
Offline edition_30
« Reply #9 on: December 11, 2009, 11:43:55 am »
Can this be done on the ed?
« Reply #10 on: December 11, 2009, 11:45:47 am »
No V6 only. :smiley:
Offline animal
  • .:R32
« Reply #11 on: December 11, 2009, 11:46:36 am »
Just chop out the backbox all together.
« Reply #12 on: December 11, 2009, 11:48:29 am »
3" pipe straight off the turbo.  :party:
Offline Jules86
  • -Receive: 46
    • Forumwars
« Reply #13 on: December 11, 2009, 11:51:30 am »
Offline animal
  • .:R32
« Reply #14 on: December 11, 2009, 11:55:50 am »
No pipe at all... straight out the turbo flange!  :laugh: Should be enough to drown out the Ed30's obese sister.
