Author Topic: VCDS Scan bringing up some faults - Anything to worry about?  (Read 2029 times)
Offline MrACD
Got hold of a friends VCDS/Vagcom and it showed the below faults..  The car has just had the chain/tensioner/adjuster replaced so battery was off and all the gubbins.  I cleared them all and went out for a drive again and they still show.  There are no warning lights on the dash and car seems to be driving great.  Any help/suggestions welcome.
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Saturday,13,June,2015,14:29:47:54416
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ5W247543   Mileage: 135280km/84059miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 A    HW: 1K0 907 115 A
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2106207
   Coding: 040300031C070160
   Shop #: WSC 00000 785 00200
   VCID: 2442792AE70F6F3EDFF-8071
1 Fault Found:
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0∞C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 042 M    HW: 02E 927 770 AD
   Component: GSG DSG         070 0824
   Revision: 04007000    Serial number: 00000504200387
   Coding: 0000020
   VCID: 1D344CCEC4655EF6901-8048
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0004738
   VCID: 3A7EA752758B09CE953-806F
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AF
   Component: ClimatronicPQ35 066 0505
   Shop #: WSC 00000 000 00000
   VCID: 6BD052164A5160465E5-803E
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H37 0803
   Revision: 00H37000    Serial number: 00000001775900
   Coding: E58D0F0600041800001400001400000000087F075C
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 00000
1 Fault Found:
01049 - Supply Voltage Term 50
            006 - Short to Plus - Intermittent
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 08 AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0CRGNU
   Coding: 0012344
   Shop #: WSC 01279 785 00200
   VCID: 3778BE66469914A66AD-8062
   Subsystem 1 - Serial number: 6332MSME0A0A5A73G
   Subsystem 2 - Serial number: 6342MSME0A0C7760E
   Subsystem 3 - Serial number: 6351HSME067F5D6FY
   Subsystem 4 - Serial number: 6361HSME066862523
1 Fault Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 G    HW: 1K0 953 549 G
   Component: Lenks‰ulenmodul 521 0050
   Coding: 0012142
   VCID: 3666B3624193EDAE71B-8063
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: Lenkradmodul    007 0050
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 970 E
   Component: KOMBIINSTRUMENT VDD 0810
   Coding: 0003403
   Shop #: WSC 00015 210 70345
   VCID: 326E8F72ADFBF18E5D3-8067
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 29001054231257
   Coding: 3F3F0340070003
   VCID: 295C681E802DB256EC9-807C
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0810
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0172
   Coding: 0000052
   VCID: 306A857AA3F7C39E2B7-8065
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.12      1502
   VCID: 316C807EA8FDCA96249-8064
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 AR    HW: 1K0 959 433 AR
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 019002085103087F2D04850560085FC690A040
   VCID: 800A95BAD3D7131E1B7-80D5
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H02 1301
   Subsystem 2 - Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
1 Fault Found:
01038 - Central Locking Thermal Protection
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 135030 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:58:20
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Component: Tuersteuergeraet 09 0120
   Coding: 0000052
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 1K0 035 186 L
   Component: Radio BVX       014 0022
   Coding: 0040402
   VCID: 2F688606BEC9DC6632D-807A
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0217
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
End   ---------------------------------------------------------------------
I also have a creaking steering rack, when manoeuvring it creaks/clicks - there is no issue with steering and road handling but it's annoying.  Think it got worse after it's been raining so may need lubrication on the joints maybe?
I didn't think owning a GTi would be such a ball ache to start with!
2005 Gti - 5dr, DSG, Black
2003 Toyota MR2 Roadster, Chilli Red
2005 Honda VFR800 Vtec
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: VCDS Scan bringing up some faults - Anything to worry about?
« Reply #1 on: June 13, 2015, 07:51:55 pm »
Most of them pointing to voltage issues,  start the car and leave it running for a few minutes,  clear the faults and see if they come back.
