Author Topic: Apr stage 2+. Ko3 dyno print outs  (Read 3108 times)
Offline ClassyDubber
« on: June 16, 2015, 02:01:14 pm »
Has anyone got a apr map on a ko3 with dyno print outs. Find mine is very underpowered
dansmith180
Re: Apr stage 2+. Ko3 dyno print outs
« Reply #1 on: June 16, 2015, 06:19:57 pm »
Have you checked your diverter valve? Could be easily losing you 50bhp+ if its split
« Reply #2 on: June 16, 2015, 09:55:43 pm »
Yes changed dv new plugs full service pcv delete. Map just doesn't seem impressive
« Reply #3 on: June 16, 2015, 10:53:11 pm »
Are you sure you have the correct map selected?
« Reply #4 on: June 18, 2015, 02:13:17 pm »
Had the stage 2 map.  Got fuel pump and went and has stage 2 +.  But not much difference
dansmith180
« Reply #5 on: June 18, 2015, 02:34:37 pm »
Yeh you should gain a lot more low down touque, not much top end though. Best thing to do is get it on the rolling road and see what's its making. Should be like 285ish BHP and 350ish lb/f
« Reply #6 on: June 18, 2015, 05:11:45 pm »
I don't know what maps you have installed but usually with APR you can switch maps with you cruise control.
I'm wondering if you somehow you have the stock map selected instead of the 2+ one...
Offline Beej
« Reply #7 on: June 19, 2015, 09:19:51 am »
I know I'm not on an apr map, but I went and spoke to an apr dealer local to me regarding some issues I was having, but they claimed that my revo 2+ map was close to figures they would get. Mine was dyno'd at 278bhp and 288lbfts if this helps. I reckon it's low, but I keep getting told it's not
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #8 on: June 19, 2015, 10:26:04 am »
Torque may be a little low but it depends on the Revo settings. Peak HP is about right, actuator pre-load and appropriate mapping (custom) needed for more.
« Reply #9 on: June 23, 2015, 12:52:55 am »
A friend has same apr stage 2 + and dyno'd around 250bhp.  Raced a stage one tfsi with a back street map and was side by side
Offline A3_Atif
« Reply #10 on: June 23, 2015, 10:24:23 am »
Whereabouts are you located? You could be losing boost or not meeting the specs on the fueling side... some VCDS logging would soon show any errors if present...
Offline DANBOY66
  • -Given: 41
« Reply #11 on: June 23, 2015, 12:14:09 pm »
@alexharvey
Alex's stage 2+ k03 r-tech tuned gti makes 280 bhp -375 lb/ft torque  :drool: it might even be a little bit more
figures look low on torque
Dan..
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #12 on: June 23, 2015, 01:30:00 pm »
@MJGib Is APR Stage 2+ Ko3.
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline alexharvey
« Reply #13 on: June 23, 2015, 10:09:22 pm »
@DANBOY66   its 289 bhp  :grin:
9 bhp is alot !!! lol
dansmith180
« Reply #14 on: June 23, 2015, 10:10:51 pm »
Dont you mean 289.45731bhp  :laugh:
