Author Topic: Help ASAP PLS  (Read 2037 times)
Offline Vwgtiking
Help ASAP PLS
« on: June 21, 2015, 03:11:20 pm »
Looking to get a wire from the engine bay to the cabin. Any help would great. I have the glove box out and nothing obvious.
Offline AndyBrown
Re: Help ASAP PLS
« Reply #1 on: June 21, 2015, 03:20:23 pm »
If it's DSG there should be a grommet where the pedals are, or so I've been told.
Offline Vwgtiking
Re: Help ASAP PLS
« Reply #2 on: June 21, 2015, 03:35:49 pm »
No it's manual will have look on drivers side
Offline doylebros
Re: Help ASAP PLS
« Reply #3 on: June 21, 2015, 03:40:30 pm »
On the passenger side behind the battery follow the main harness back this is an easy route through the firewall.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Help ASAP PLS
« Reply #4 on: June 21, 2015, 05:29:39 pm »
I followed this route the other day,  removed the battery and battery tray, on the right of the abs pump is a rubber grommet,  feed through a metal hanger wire and you will see if come out in the passenger footwell just behind the footwell light in top left corner,  you will need to remove the foam above the passengers footwell to see it
Re: Help ASAP PLS
« Reply #5 on: June 21, 2015, 05:38:17 pm »
This ^^^
Offline Vwgtiking
Re: Help ASAP PLS
« Reply #6 on: June 21, 2015, 07:10:27 pm »
Oh right. I didn't remove battery but I couldn't see anything obvious.
Re: Help ASAP PLS
« Reply #7 on: June 22, 2015, 12:07:37 am »
theres a rubber bung, has a few little rubber teets/ Nipples on it (Haha, nipples).  Snip one of the nipples and feed your wire through
