Author Topic: Anyone work at VW that can check a TSB for me?  (Read 1523 times)
Offline GTi-Andy
« on: June 24, 2015, 08:52:58 am »
Ive run a VCDS scan a keep getting the following codes, although ti doesn't seem to affect performance/running of the car etc.
However after searching around on the net there seem to be talk of a TSB for these codes, can someone please help??
008200 - Intake Manifold Flap; Bank 1
               P2008 - 001 - Electrical Malfunction
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 71797 km
                    Time Indication: 0
                    Date: 2012.14.10
                    Time: 15:01:29
             Freeze Frame:
                    RPM: 1337 /min
                    Load: 13.3 %
                    Speed: 26.0 km/h
                    Temperature: 27.0°C
                    Temperature: 13.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.478 V
012600 - Intake Manifold Runner Control
               P3138 - 008 - Regulation Deviation
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 71797 km
                    Time Indication: 0
                    Date: 2012.14.10
                    Time: 15:01:29
             Freeze Frame:
                    RPM: 1337 /min
                    Load: 12.5 %
                    Speed: 26.0 km/h
                    Temperature: 27.0°C
                    Temperature: 13.0°C
                    Voltage: 14.478 V
So much for keeping it standard!
Re: Anyone work at VW that can check a TSB for me?
« Reply #1 on: June 24, 2015, 09:56:49 am »
What year is your car?
IMO you need to replace the flapper motor. There was a tsb to update the software but that didn't work for most and required a new motor.
Offline GTi-Andy
« Reply #2 on: June 24, 2015, 10:06:26 am »
@bacillus 2007 AXX engine
I was hoping that the software update would solve it before going down replacing the motor route.
Is the new motor covered by the TSB?
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #3 on: July 16, 2015, 05:05:29 pm »
Have you actually tried to manually move the flaps?
And questions questions: what oil do you use, and what air filter is fitted?
Offline GTi-Andy
« Reply #4 on: July 16, 2015, 10:17:07 pm »
No need at all for that flippant answer pal. All I need to know if there's a TSB that I could pursue.
