Author Topic: VW washer fluid - only applicable if running Winter Pack?  (Read 4342 times)
Offline em2evol
  • Let's Motorvate!
Re: VW washer fluid - only applicable if running Winter Pack?
« Reply #15 on: December 14, 2009, 05:01:06 pm »
VW stuff costs about the same as other stuff but smells loads nicer I think so it's a no brainer for me!   :xmassmiley:
Offline rskardon
« Reply #16 on: December 14, 2009, 05:16:25 pm »
I've used Halfords apple stuff for about 2 years now and mine havent blocked at all,
R
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #17 on: December 14, 2009, 06:16:46 pm »
Sometimes all of this does make me wonder... if manufacturers scaremonger people into buying their "official" stuff  :scared:
Offline TomB
« Reply #18 on: December 14, 2009, 06:26:44 pm »
It does happen, I've seen clogged up hoses at work quite a few times.
You find a hard blob of blue (its always blue!) stuck up the tube, this happens when the screenwash goes back to gunk at the bottom of the tank.  Most of the time the problem can be fixed with some boiling water and a minute with the pump on, but it can set like plastic in there if you don't use them often.
A few years back on SCN, one of the users with a Yellow Ibiza filled up with Halfords screenwash, used it and found the green colouring had dyed his paint.  No polish could remove it either, I'm sure they had to pay up for a respray in the end!
« Last Edit: December 14, 2009, 06:29:36 pm by TomB »
Tom
05 GTI - 18" Merc wheels, coilovers, colour coded Votex kit, all waiting to go on.
Offline DanoGTI
    • DA Productions
« Reply #19 on: December 14, 2009, 06:35:45 pm »
Well the irony is that I've filled the tank with regular (non-vw) water  :wink:
And I've noticed that my jets are blocking up  :fighting: Not fookin happy.
Suggestions as to how to clear them? :sad:
Looks like I'm gonna need em over the next few days with the snow too.
Fook
Dan
DA Productions
The fine art of diplomacy is telling somebody to "fcuk off" in such a way that they actually look forward to the journey....
Offline TomB
« Reply #20 on: December 14, 2009, 06:58:06 pm »
Hot water is your friend, take the jets out and put them in a bowl of hot water and blow out the gunk, and fill your washer bottle with hot water and start the pump.
Tom
Offline DanoGTI
    • DA Productions
« Reply #21 on: December 14, 2009, 07:00:26 pm »
Ahhh, that could be good news. How do you remove the jets?
Dan
DA Productions
Offline DanoGTI
    • DA Productions
« Reply #22 on: December 14, 2009, 08:15:46 pm »
scratch that - sorted in the dark!!  :happy2:
Think it pretty much sorted though hard to tell in the p1ssing rain, and it was dark!!  :grin:
DAn
DA Productions
