Author Topic: Runner Flap Issue  (Read 684 times)
Offline jakex181
Runner Flap Issue
« on: June 25, 2015, 07:08:14 pm »
Engine light came on earlier, did a scan with Vagocom which revealed this:
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 J    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H14---    Serial number: VWZ7Z0F8040446
   Coding: 0403000318070060
   Shop #: WSC 00200 210 89989
   VCID: 2D577FEFB493EC7600B-8078
3 Faults Found:
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 154200 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 50.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 1030.0 mbar
                    Voltage: 11.811 V
012599 - Intake Manifold Runner Control
               P3137 - 001 - Basic Setting not Completed - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 154913 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 54.0°C
                    Temperature: 51.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.065 V
001602 - Sensor Reference Voltage A: Circuit
               P0642 - 002 - Low - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 154913 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 54.0°C
                    Temperature: 51.0°C
                    Voltage: 12.192 V
Readiness: 0000 0000
I reset the codes and also performed a basic setting which i found was recommended after an online search. I also tried an output test and the runner flap motor was functioning fine. Ive had this code before a while ago.
Is this a major problem? How can it be fixed for good?
Cheers!
