Author Topic: Lights on warning?  (Read 3638 times)
Offline Vwgtiking
Lights on warning?
« on: June 27, 2015, 06:43:55 pm »
I left my lights on after i turned my ignition off,  door open and no warning beep.
But soon as I turn to the side light option with the door open then the warning beep goes off.
Is this normal??
« Last Edit: June 27, 2015, 07:01:25 pm by Vwgtiking »
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
Re: Lights on warning?
« Reply #1 on: June 27, 2015, 08:20:43 pm »
Do you have auto lights?
Offline Vwgtiking
« Reply #2 on: June 27, 2015, 08:22:30 pm »
I think so. I have off. Then an option, then side lights then main lights. Total four options.
Offline TAPPY
  • -Receive: 56
« Reply #3 on: June 27, 2015, 08:25:32 pm »
with mine I get a beep if I leave them on and open the door but if it's set on auto (second option) then it won't beep.
Offline TAPPY
  • -Receive: 56
« Reply #4 on: June 27, 2015, 08:26:29 pm »
I believe it's because when on auto they turn themselves off after like 30 seconds or so
Offline Vwgtiking
« Reply #5 on: June 27, 2015, 08:26:46 pm »
No mines on the last option. But it's odd that it beeps with sidelights and not main lights.
Offline Vwgtiking
« Reply #6 on: June 28, 2015, 10:18:41 pm »
Anyone else?
Offline Vwgtiking
« Reply #7 on: July 07, 2015, 10:17:51 pm »
Up
Offline Vwgtiking
« Reply #8 on: July 08, 2015, 03:19:25 pm »
I changed switch and now the sidelights warning is no longer as well.
Offline MrACD
« Reply #9 on: July 08, 2015, 03:36:30 pm »
Leave it on auto  :signLOL:
I'm not sure if it's a programmable item with VCDS.. maybe fire someone with VCDS a pm.  :happy2:
2005 Gti - 5dr, DSG, Black
2003 Toyota MR2 Roadster, Chilli Red
2005 Honda VFR800 Vtec
Offline Vwgtiking
« Reply #10 on: July 08, 2015, 04:13:56 pm »
I have full vcds with no faults
Offline MrACD
« Reply #11 on: July 08, 2015, 06:15:59 pm »
Offline Vwgtiking
« Reply #12 on: July 08, 2015, 06:20:09 pm »
The warning for the sidelights is actually working it's only if you leave the main lights on I get no warning. I have wired an illumination wire the grey wire behind the switch. Will somehow affect it??
Offline Vwgtiking
« Reply #13 on: July 08, 2015, 06:58:48 pm »
The other thing is I turned off seatbelt warning but that shouldn't effect it should it?
Offline Vwgtiking
Lights on warning?
« Reply #14 on: July 08, 2015, 07:32:14 pm »
Another update.
Can someone please check there's too.
When I have the key in turned to position 1 after engine running with headlights on upon turning engine off, if I select auto or sidelights, nothing changes, the normal headlights are still on??????  Beeps only on when actual sidelights are physically selected by switch with door open. Yet pls note when selecting sidelights the main lights remain after engine just running.
Wtf is going on?
« Last Edit: July 08, 2015, 07:34:22 pm by Vwgtiking »
