Author Topic: Bottom end (short motor) are DSG and manual the same? And will AXX head fit bwa?  (Read 3864 times)
Offline Ricky123
  • -Receive: 27
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98436.0.html
Probably a stupid question but I saw an a5 tfsi bottom end advertised and it said in the add that it's different to the manual one...
I've just saw a mk5 gti bottom end for sale removed from a dsg car but mine is manual so just want to be certain there not different before I bother going to look at it.
Also the bottom end I'm interested in is a BWA engine and I'd be using the head off my current engine AXX will it work?
Need help guys lol and ASAP  :happy2:
56 mk5 ed30 3dr
57 mk5 1.9 TDi match
22 a3 s-line competition 45 tfsiE
09 Suzuki GSXR 1000 (road going track sl*g)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Bottom end fits and AXX head fits on BWA engine, but all aux. has to be transferred from you current engine as you have longitudinal and the other is transverse  :happy2:
Over the top mod list ;o)
Offline Ricky123
  • -Receive: 27
The bwa short motor I'm interested in isn't from the a5 I just saw that advertised and is stated that dsg block was somehow different to manual so assumed that most tfsi blocks are pretty much all the same
The bwa I'm interested in is from a mk5 golf gti and will be going into a mk5 gti so shouldn't need to swap that over?
So 100% my AXX head will fit? And it will doesn't matter if it's DSG going on a manual?
56 mk5 ed30 3dr
  • -Given: 243
  • -Receive: 154
yes, the heads are interchangeable :)
Offline Sara
I was wondering similar thing i have been using axx top half of engine with Bwa bottom now have problem where I have parts from both engine spare yet garage says they are not compatible as head hits piston? Surely this is wrong? Any suggestions ?
Offline Ricky123
  • -Receive: 27
Nope they work fine I combined both in the end without any issues
56 mk5 ed30 3dr
Offline Sara
Basically I had AXX engine then bought BWA from breakers down south which in the end up the head was goosed so got my original head (AXX) got it skimmed and used the valves from (BWA) to repair my original head so (AXX) head went onto (BWA) bottom end so all was looking sweet and work was coming closer to the end
Fitted engine was slight Miss fire cylinder 2 then problems with oil pressure so after several months of saving money to keep trying to repair it and cost down the oil pressure was repaired that was all good then about 2months later started viberating shaking pretty bad so changed coil packs and plugs at times it calmed down then gets worse in time still misfire cylinder2  so thought might be fuel injector changed that with seals then BOOM no f*****g changes
Michaeldal
Im a little confused and perhaps dense, but do you buy the garbage bags BEFORE or AFTER the paint pen??
Offline Ricky123
  • -Receive: 27
Dsg and manual bottom ends are compatible with both style of gearbox
Axx and bwa heads and bottom ends are both interchangeable with each other
Have you had vcds scan done on your car? If your still getting a misfire on cylinder 2 after changing plugs, coil pack and injector then the next thing to do is a compression test
Where abouts are you located? If your not too far from me then I'd be happy to come and have a look at it.
« Last Edit: March 01, 2016, 12:59:52 am by Ricky123 »
56 mk5 ed30 3dr
