I have the premium sound pack which is quite good, but since I have upgraded from RCD500 to RCD510, the output is too loud. VW have clearly put a MUCH louder amp in the new head unit, so the separate power amp is not needed. It means that I can't put the volume up more than half way.
I want to remove the amp and do without it. Does anyone know if this can be done? I have unplugged it, but then I get no output at all (obvious!). Would I need to rewire the whole audio system to remove it?
Can you get a 'pass though' connector so that the amp can be removed and the connectors put together? I have tried to do this myself with a few wires and it does work, but I don't know which pins are which speakers and there are 20 connections to match! 20x20= a lot of possible permutations.
I have dismantled the amp in the hopes of finding a gain control, but there's nothing, so I had to put it back in
