Author Topic: Painting brake calipers  (Read 2025 times)
Offline RedGolfDom
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99951.0.html
« on: July 02, 2015, 05:33:58 pm »
Going to be painting my brake calipers yellow in the next couple of weeks so just wondering what paint have people used? Seen a few people say they use a brush one and others spray. And also because I'm going to probably just do it whilst theyre still on should I remove the pads before painting and mask everything else?
Mk5 golf gt 140
Revo stage 1
Air lift Performance 3p
Offline jaffa
  • -Receive: 44
Re: Painting brake calipers
« Reply #1 on: July 02, 2015, 05:51:43 pm »
Iv just painted mine using E-Tech paint i was quite impressed with it, dries within 30 mins for recoat and a nice smooth finish
They were previously painted using Foliatec paint + hardener, was also impressed with this but it dries as more of a plastic feeling when dry
With both paints i used a flat artist brush as it gives a fantastic smooth finish and makes getting into small spaces easier
For the backs i removed the calipers and pads for the fronts i removed the anti rattle clip
depending on how good of a painter you are you don't really need to mask anything for painting with a brush (I'm a decorator so i didn't mask)
If you go the spray route then EVERYTHING needs to be masked that you don't want painting
Foliatec
E-Tech
Offline RedGolfDom
« Reply #2 on: July 02, 2015, 07:05:27 pm »
Thanks man! I'll probably go the brush route then as it seems like it would be easier to do! Also nice jobs on yours  :congrats:
Mk5 golf gt 140
Revo stage 1
Offline Golf_GT_TDI
  • -Given: 45
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89458.0.html
« Reply #3 on: July 02, 2015, 08:03:36 pm »
+1 for brushing on, I recommend paint from here, best I've ever used...
http://www.brake-caliper-painting.com/high_temperature_brake_caliper_paint.html#.VZWJtE0nQTg
Offline th3_f15t
  • -Receive: 183
« Reply #4 on: July 02, 2015, 10:33:07 pm »
Also, clean everything as well as you can before painting.
I'm lead to believe a light sanding before painting as well (and a further good clean) makes the finish even better?
Offline markos
« Reply #5 on: July 02, 2015, 10:48:40 pm »
I painted mine black with radiator paint so the heat wouldn't cause problems
Offline Ruggy
« Reply #6 on: July 02, 2015, 11:00:25 pm »
To be fair, any old enamel paint will be fine, it's no different to the Foliatec or E-Tech stuff.
You might as well save the cash and just buy Hammerite.
I used it on my Corrado calipers and it was on there until I sold the car about 4 years later. Never had any problems or issues with heat etc.
Special caliper paint is just a scam.
Offline markos
« Reply #7 on: July 02, 2015, 11:19:08 pm »
Yep, hammerite is what I used  :happy2:
Offline PM30S
  • Edition 30 Revo Stage 2+
« Reply #8 on: July 03, 2015, 08:41:16 am »
TOTALLY AGREE JUST USE HAMMERITE BEST STUFF.
