Author Topic: Mk6 climatronic in golf mk5 gti  (Read 10359 times)
Offline K9
  • VW LifeStyle
Re: Mk6 climatronic in golf mk5 gti
« Reply #15 on: July 06, 2015, 10:58:43 pm »
I'm not getting the loom so whats the best i can do?
Writen with my fingers
Offline Softishman
« Reply #16 on: July 07, 2015, 02:17:00 am »
Then remove both pins and cut the black/green off (you don't use it anyway) snd solder it to the other red/yellow cable.
Offline K9
  • VW LifeStyle
« Reply #17 on: July 07, 2015, 04:32:55 pm »
@Softishman  whats the best way to remove the pins from the connectors without damaging anything?
i cant find a trim for the mk6 unit  :surprised:
« Last Edit: July 07, 2015, 05:04:07 pm by K9 »
Offline Softishman
« Reply #18 on: July 07, 2015, 08:43:23 pm »
I bought a cheap kit frim ebay, vw pin removal tool kit or something like that...
The trim piece i bought from vw dealer, if you google mk6 clima on mk5 you will find some old threads that tells witch art nr you need!!
Ebay item nr:
252004726747
Offline doylebros
« Reply #19 on: July 07, 2015, 09:37:22 pm »
You could use this tool
http://www.ebay.co.uk/itm/Laser-3932-Terminal-Tool-/311171376685?pt=LH_DefaultDomain_3&hash=item487342662d
Offline K9
  • VW LifeStyle
« Reply #20 on: July 07, 2015, 09:39:28 pm »
Great will order it tomorrow! Can these be found in local electric stores?
Offline doylebros
« Reply #21 on: July 07, 2015, 09:47:14 pm »
Possibly in Andrew Pages or another motor factors but they will be more expensive than eBay!
Offline K9
  • VW LifeStyle
« Reply #22 on: July 07, 2015, 09:52:01 pm »
So 3932 tool is the correct to remove one or both pins?
Offline doylebros
« Reply #23 on: July 07, 2015, 10:03:54 pm »
I've not got one I had to buy a kit but It should do the job - watch a few YouTube videos to help you out https://m.youtube.com/watch?v=1OQevVIglTE
« Last Edit: July 07, 2015, 10:12:00 pm by doylebros »
Offline K9
  • VW LifeStyle
« Reply #24 on: July 07, 2015, 10:29:28 pm »
Guess i will order the tool. I don't want to do any damage to it if i will re-install the mk5 unit sometimes.
Offline USBulldog
  • Has a beard!
« Reply #25 on: July 07, 2015, 10:37:48 pm »
You want to go to VW and ask for a Jetta with climatronic surround. They are order in but £12!! I didn't like the mk6 in mine so got rid.
Offline K9
  • VW LifeStyle
« Reply #26 on: July 07, 2015, 10:38:58 pm »
Why jetta and not golf mk6 surround?
Offline USBulldog
  • Has a beard!
« Reply #27 on: July 08, 2015, 07:01:44 am »
The mk6 surround is a different shape to the mk5, it starts under the radio and only covers the heater controls. The mk5 surround goes up to the top of the radio almost. Check out some pictures you'll see the difference. The Jetta surround is the shape you need. If you search for old posts on here and elsewhere on the net, it has been covered hundreds of times before and someone even shares the PN for the Jetta surround. I gave the receipt to the new owner of mine so don't have it to hand.
Offline K9
  • VW LifeStyle
« Reply #28 on: July 08, 2015, 10:49:01 am »
Ain't the golf mk6 climatronic surround same as jetta?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #29 on: July 08, 2015, 11:26:15 am »
@K9 Com'on man! You were told they're different. Do a bit of research before making questions and listen to the people trying to help you. :wink:
You can easily search a picture of a Golf mk6 dashboard and see that the surround is different. You need the Jetta mk6 surround. Done!
