Author Topic: ED30 Complete Power Loss - Solved?  (Read 2916 times)
Offline dom069
« on: July 03, 2015, 09:18:28 pm »
Just had a message from my brother saying that his ed30 has lost all power. He was going up a hill, power completely went esp and epc lights came on.
It will drive on the flat but will only Rev to 1800, if he tries to drive up hill it stalls. He's had it recovered to a garage, obviously the first step will be to scan for codes but what should be checked next? Diverter valve? Pcv?
« Last Edit: July 11, 2015, 03:38:25 pm by dom069 »
BC Racing Coilovers : R32 Rear Bumper : Milltek Cat Back : R32 Rear Lights : S3 Brakes : Colour Coded Side Skirts : US Grill : 18" BBS CH : De-Wipered : Bluefin Remap : Pipercross Filter : S3 Short Shifter : Powerflex Wishbone Bushes : MK6 Steering Wheel : RCD510
Re: ED30 Complete Power Loss
« Reply #1 on: July 03, 2015, 09:27:28 pm »
Throttle body motor failure???
Offline th3_f15t
  • -Receive: 183
« Reply #2 on: July 03, 2015, 10:07:17 pm »
The full checks, DV, PCV and cam follower. Did he see any smoke from the exhaust after the power went? If so, what colour?
Offline dom069
« Reply #3 on: July 05, 2015, 06:57:21 pm »
He doesn't remember seeing any smoke but he probably wasn't paying attention tbh. Cam follower was changed recently and DV is relatively new but he'll get them checked anyway. I'll report back when he knows more  :happy2:
Offline dom069
« Reply #4 on: July 05, 2015, 08:36:11 pm »
Does sound like throttle body  :sick:
I'm assuming that a fault code will be logged if that's the case? Any idea of cost on a replacement throttle body?
« Reply #5 on: July 05, 2015, 11:26:44 pm »
New TB is a little over £300 notes...   :scared:
Offline dom069
« Reply #6 on: July 06, 2015, 02:51:39 pm »
So it was scanned for codes and threw up:
P0222 - Throttle/Pedal Position Sensor B - below lower threshold
This was cleared, car was driven and drove ok briefly until power was cut again, management light didn't come on initially but did after a short while. It was scanned again and showed the following codes:
P1093 - Fuel measuring 2 system 1 bank - not consistent signal
Now P0222 shows as:
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Fuse(s) faulty
Wiring and/or Connector(s) from/to Throttle Angle Sensor 2(G188) faulty
Possible Solutions
Check Fuse(s)
Check Wiring and/or Connector(s) from/to Throttle Angle Sensor 2(G188)
Check/Replace Throttle Angle Sensor 2(G188)
Check Measuring Value Blocks (MVB)
P1093 is:
Possible Symptoms
Power Loss
Misfire(s)
Stalling
Possible Causes
Fuel Pressure insufficient/exceed/fluctuating
Fuel Pump (High Pressure System) faulty
Fuel Pressure Regulator Valve (N276) faulty
Possible Solutions
Check Fuel Pressure (on FSI engines High and Low Fuel Pressure System)
Check Fuel Pump (High Pressure System)
Check Fuel Pressure Regulator Valve (N276)
Check Fuel Filter and Filter in Fuel Pump Casing
« Reply #7 on: July 06, 2015, 03:15:56 pm »
IMO you need a new TB as one of it's internal sensors is faulty.  :sad1:
Offline dom069
« Reply #8 on: July 06, 2015, 03:35:20 pm »
Other than swapping out the TB for another one is there any way of confirming that it's at fault? @bacillus
Offline dom069
« Reply #9 on: July 06, 2015, 08:15:11 pm »
After a conversation with Matt and Only Charged Dubs he suggested a faulty throttle pedal sensor. Does anyone know if my 05 Gti throttle pedal will be the same as his 07 ED30 one?
« Reply #10 on: July 06, 2015, 08:37:21 pm »
The error P0222 - Throttle/Pedal Position Sensor B - below lower threshold suggests the issue is your throttle body that includes its 2 sensors. Your throttle body is attached to the lower side of your intake manifold.
IMO Changing your throttle pedal is unlikely to be of any use...
Offline dom069
« Reply #11 on: July 11, 2015, 02:22:16 pm »
Just to update this, he ordered a pedal from VW and fitted it this morning. We took it out and it boosted and ran fine until it shifted gear under full throttle. Then it went straight back into limp mode.
We got it back and I decided to check the cam follower and pcv valve for piece of mind. Cam follower was ok, however idle didn't change when the dipstick was pulled.
I swapped my pcv valve onto his, took it out again and it looks like no more limp mode!
