Author Topic: Key cutting  (Read 3406 times)
Offline Vwgtiking
Key cutting
« on: July 04, 2015, 12:11:22 pm »
Just had my key cut a local Key cutting place and it didn't work. It wouldn't turn the ignition nor lock/unlock door. The guy seemed quite surprised. Are the blades are hard to do???
Called vw and they don't even cut them????
I got a refund anyhow. Do timpsons cut car keys??
Offline danfalcon
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92069.0.html
Re: Key cutting
« Reply #1 on: July 05, 2015, 07:07:25 pm »
message this guy on facebook https://www.facebook.com/craig.nettleton.9?fref=ts
he is an autolocksmith that travels the country!
can even supply bentley keys, really good bloke and really good price
Offline Vwgtiking
Re: Key cutting
« Reply #2 on: July 22, 2015, 10:40:12 pm »
Timpsons £5. Done!
Re: Key cutting
« Reply #3 on: July 23, 2015, 03:59:22 pm »
They do, just not at the dealers.   The process at VW is you walk into a dealer, hand them your V5 document and driver's license, give them 200ish quid and then a couple of days later the key turns up ready cut and programmed to your car.   Not cheap!
Offline Vwgtiking
Re: Key cutting
« Reply #4 on: July 23, 2015, 08:34:45 pm »
They told me they can order me the key but I must get it cut locally ie at timpsons.
Re: Key cutting
« Reply #5 on: July 24, 2015, 10:35:37 am »
Gotta love the inconsistency of the dealer network.  The lock profiles are stored centrally at VW HQ for every chassis number.  That's where they are cut.  The local dealer then does the programming on site.
Offline Vwgtiking
Re: Key cutting
« Reply #6 on: July 24, 2015, 12:23:35 pm »
lol. It took me 2mins to code mine myself. And 5mins for timpsons to cut it.
Re: Key cutting
« Reply #7 on: July 24, 2015, 02:09:20 pm »
Yeah you can add a new alarm plipper to the car yourself easily, but the immobiliser bit is the tricky part.  Can Timpsons do that bit?
Offline bigeyd
  • -Receive: 31
Re: Key cutting
« Reply #8 on: July 24, 2015, 02:20:13 pm »
The last time I asked it was 120 but the remote will not shut/open windows for some reason ?
Offline Vwgtiking
Re: Key cutting
« Reply #9 on: July 24, 2015, 03:43:11 pm »
Timpsons cut key blade. I match transponder to immobiliser and matched the remote all via vcds.
Re: Key cutting
« Reply #10 on: July 24, 2015, 03:49:10 pm »
Yeah my full closure hasn't worked either since I upgraded to a newer CAN gateway (RNS510 battery drain).  I think I need to 'relearn' it or something!
Re: Key cutting
« Reply #11 on: July 24, 2015, 03:49:32 pm »
Good to know you can do all that with VCDS, cheers!
Offline bigeyd
  • -Receive: 31
Re: Key cutting
« Reply #12 on: July 25, 2015, 08:35:03 am »
How do you get SKC code ?
Offline Vwgtiking
Re: Key cutting
« Reply #13 on: July 25, 2015, 10:10:50 am »
Vag commander.
