Author Topic: big cooling fan problem need help asap !!!!!  (Read 977 times)
Offline Daled0111
  • -Given: 26
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,95386.0.html
« on: July 05, 2015, 03:33:58 pm »
hello i have got a problem with my cooling fan, the fan is staying on full speed even when i turn the car off and lock it, it is still on full speed the only way to stop it is to unplug the connector i am trying to fine the control units location but cant find it anywhere online
these are pictures of the unit and just wondering if anyone has come across this or know where the unit is on the car
or is this for a different model and is the control unit built into the fan
« Last Edit: July 05, 2015, 07:00:44 pm by Daled0111 »
Offline Craigh1983
    • Leicester Wedding Photographers
Re: big cooling fan problem need help asap !!!!!
« Reply #1 on: July 05, 2015, 08:47:43 pm »
Hi there,
I can't help with where the control u it is however I've just had the same problem as you apart from my fan would stop when I take the key out of the car. When I was stuck in traffic and the temp was getting to the stage where the fan would kick in, it would turn on and then go full pelt and not slow down even if I switched the ignition off. I had to take the key out before it stopped.
In the end I had to take it to Alex at AKS Tuning and had the fans replaced and this has fixed the problem!
Hope u get it sorted mate
Offline Ricky123
  • -Receive: 27
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98436.0.html
« Reply #2 on: July 05, 2015, 08:58:08 pm »
Had a 2007 a4 tdi with the same problem as you. Ended up being a relay at fault. Different car but worth checking.
56 mk5 ed30 3dr
57 mk5 1.9 TDi match
22 a3 s-line competition 45 tfsiE
09 Suzuki GSXR 1000 (road going track sl*g)
Offline Daled0111
  • -Given: 26
« Reply #3 on: July 06, 2015, 01:48:51 pm »
Can't find the relay anywhere
