Author Topic: rear camber adjustment  (Read 19072 times)
Offline jimmy-s3
« on: December 13, 2009, 03:05:18 pm »
Can anyone give me an idiot proof guide to adjusting the rear camber on my car please. Ive just fitted a set of new wheels and the nsr is rubbing. Looking at the car from the back, the osr wheel has more angle on it then the other side.
Offline jonnyc
  • Herrooooo!
Re: rear camber adjustment
« Reply #1 on: December 13, 2009, 03:30:49 pm »
Don't have a guide, but I would say that adjusting camber, or any geometry settings, is not an eye it up type of job.. You need to have it set up and measured to be sure you don't turn your car into an oversteery mess..
The adjustment on the rear camber comes from the cam bolt on the inner side of the rear bottom arms, rotate them and it will move the bottom arm, in or out from the centre line of the car adding or taking away camber..
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #2 on: December 13, 2009, 03:54:57 pm »
.........it's recomended after any wheel/suspension change to have a full tracking check done.Get down to you'r local tyre place.  :smiley:  :happy2:.
Offline jimmy-s3
« Reply #3 on: December 13, 2009, 05:06:30 pm »
Think i'll take it to where i had my bmw done. They charged £30 for it. Do you think they will set the camber up to factory set up or will they do it to how i want it??
Offline jonnyc
  • Herrooooo!
« Reply #4 on: December 13, 2009, 05:25:11 pm »
Dont think it makes any difference to them does it? Just request a setting if you know what you want  :smiley:
Offline pazz
« Reply #5 on: December 15, 2009, 09:59:24 am »
Whats the rim width and offset on the new wheels? Is the car lowered?
There is nothing wrong with the factory setup. Dont forget that when you lower a car you change the whole geometry of the car suspension.
If you've just fitted bad wheels then camber may solve the rubbing problem but will not help cornering.
Offline jimmy-s3
« Reply #6 on: December 15, 2009, 04:35:40 pm »
The rim size on the new wheels is 8 or 8.5 im not too sure and the offset i think is 40. (BBS CH reps). Just looking at the car from the rear you can tell the camber is not matching up on both sides. I want it set up to factory really but i think they will rub like mad !
Offline pazz
« Reply #7 on: December 15, 2009, 06:02:27 pm »
Is the car lowered? If so springs or coilovers?
A bit unusual for the camber to just be out on one side if you've not lowered it.
Offline jimmy-s3
« Reply #8 on: December 15, 2009, 06:36:35 pm »
Yeah its on coilovers!
« Reply #9 on: December 15, 2009, 09:56:51 pm »
This is going to sound mad but i think the drivers side rear set up sticks out about 2 mil further.  :chicken:
When i was setting mine up, or rather VWR were, i kept getting rubbing on the drivers side only. Even when they measured both sides and matched the coils accordingly.
Also if you have got 8.5j wheels with 40 offset then you will get rubbing on severe compression no matter what you do unless you add lots of camber.  :santa:
Offline pazz
« Reply #10 on: December 15, 2009, 10:04:44 pm »
I wrote a lengthy post, but it timed me out! Fkin awesome forum!
Cutting the story short, I'd take it along to a wheel alignment specialist and get them to inspect. Did you fit the coilovers yourself?
« Reply #11 on: December 15, 2009, 10:05:58 pm »
 :grin:   all you have to do is press post again, and this solves the time out.  :laugh:
Offline pazz
« Reply #12 on: December 15, 2009, 10:09:05 pm »
It asked me to log back in, so I did. And then it just displayed a blank reply box stating that I'd left it blank???
« Reply #13 on: December 15, 2009, 10:12:39 pm »
Ah i see, i thought you meant the post timed out. Being timed out on the forum is a strange one, it happens to a few people even when you select stay logged in always.  :rolleye:
Offline pazz
« Reply #14 on: December 15, 2009, 10:17:22 pm »
Mine was set to 240 minutes, but it sure as hell didnt take 4 hours to write! I've ticked the box for "always keep me logged in". Thanks the help TC. Apologies for off-topic Jimmy-S3
