Author Topic: MK5 2.0 TFSI BYD Oil Cooler?  (Read 1635 times)
Offline s31teg
« on: July 07, 2015, 05:24:57 pm »
Hello
Im trying to fit and external oil cooler to my ED30 BYD 2.0 TFSI but it has the rectangle oil cooler instead of the round type that is easy to get the sandwich plate for.
Does anyone know a solution to resolve this?
Thanks in advance...
Offline Paradox1
  • -Given: 41
Re: MK5 2.0 TFSI BYD Oil Cooler?
« Reply #1 on: July 08, 2015, 10:58:37 am »
one side of the rectangluar braided pipes would go to one of the takes off from the snadwich plate
Offline s31teg
« Reply #2 on: July 31, 2015, 01:42:46 pm »
There is no sandwich plate available unfortunately.
No one know of anyone that has done this before?
Offline Paradox1
  • -Given: 41
« Reply #3 on: August 21, 2015, 10:18:54 am »
ok i think you'll need a sandwich plate then. sandwich plate goes under the oil filter. the plate should have a few take of pipes where you screw you oil cooler hose into
Offline flashp
  • -Receive: 65
« Reply #4 on: August 21, 2015, 11:55:22 am »
Will a sandwich plate work with our filters?
I haven't done my own filter changes but isn't it an element inside a housing rather than a screw on canister?
Gone but not forgotten :-)
Offline s31teg
« Reply #5 on: August 21, 2015, 12:02:43 pm »
Yeah that's the problem. I can't find a solution. I know what to do but can't find anyone to supply a way to tap off the oil threw the cooler. Ideally a thermostatic type too.
Offline vRSAlex
  • -Receive: 253
« Reply #6 on: August 21, 2015, 02:29:28 pm »
I can put a kit together.  Removes the original oil/water cooler and replaces it with a plate.  We use an inline thermostat and a 16 row mocal oil cooler.
Follow AKS tuning on Facebook
Offline Paradox1
  • -Given: 41
« Reply #7 on: August 21, 2015, 02:38:23 pm »
Have you got pics and prices Alex?
