Author Topic: Camshaft swap.. Any special tools needed?  (Read 4716 times)
Offline Ricky123
  • -Receive: 27
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98436.0.html
« on: July 08, 2015, 08:52:33 pm »
Evening...
Starting the process of building my engine up on Friday, I've bought a complete BWA lump with a snapped cambelt to replace my nackered AXX.
Since the BWA head needs work (valves,guides etc) due to the cambelt miss hap im going to be running my AXX head on the BWA bottom end. The BWA cams that came with the engine are mint (40k miles)
I've read a few things about camshafts snapping and camshaft wear etc, am I right in thinking the BWA cams are stronger or better in some way to my AXX ones?
I was going to just put my head on as is but am I better off sticking the BWA camshafts in my head as I'm building it up?
If so then are there any special tools needed? Bear in mind both heads of are off and on a work bench. I've not taken the timing chain covers off yet.
I did read a timing chain replacement DIY thread and it said something about a camshaft tool? Is it just an m10 ribe key or spline socket? Or is it actually a VW special tool?
Any help would be great. Thanks
56 mk5 ed30 3dr
57 mk5 1.9 TDi match
22 a3 s-line competition 45 tfsiE
09 Suzuki GSXR 1000 (road going track sl*g)
Offline doylebros
Re: Camshaft swap.. Any special tools needed?
« Reply #1 on: July 08, 2015, 09:06:32 pm »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=8tkfts7gqaf8mtcu1mh6jcuu0t&/topic,90967.msg917089.html#msg917089
« Reply #3 on: July 08, 2015, 09:21:28 pm »
Don't both engines have the same cams? If your axx intake cam is not foobared can i have it? Unless someone recommends i buy a new one.
I have these tools if u want to borrow them? The spline bit is original. The cam lock took is not. But a few members have used it with no problems.
05 | Tornado Red | DSG
Offline Ricky123
  • -Receive: 27
« Reply #4 on: July 08, 2015, 09:24:30 pm »
Both my AXX cams are fine. I'm sure I remember reading something about the cams being weaker and snapping or something like.
Where are you based? If they are the same then I don't mind you having an intake came or if they are different then I'm happy to give you a cam in exchange for the use of tools.
Either way you can have an intake cam.
« Last Edit: July 08, 2015, 09:37:40 pm by Ricky123 »
56 mk5 ed30 3dr
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #5 on: July 08, 2015, 09:37:24 pm »
I'm in Spain mate. But the tools are in my office in london.
That may have been the one piece rev A cam? I'm sure someone will chime in if the cams from the BWA are better.
Offline Ricky123
  • -Receive: 27
« Reply #6 on: July 08, 2015, 09:40:45 pm »
Ok well I'll try and find out if they are. What are the cam differences on this engine range? Rev A etc?
How will we go about exchange if I need the tools as I'm in Manchester? If I don't need them then I'm happy to send you an intake camshaft for nothing if you pay the postage cost
56 mk5 ed30 3dr
Offline doylebros
« Reply #7 on: July 08, 2015, 09:45:54 pm »
Remember to remove the sump and replace or clean the oil pick up pipe
http://www.mk5golfgti.co.uk/forum/index.php/topic,68442.0.html
Common for them to be minty cause oil starvation to the top end of the engine causing the problem with the cams and chains etc.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #8 on: July 08, 2015, 09:56:15 pm »
If you need the tools i will get them posted to you and you send them back to my office with the cam??
If you dont need them i can paypal you the shipping?
Rev A on the Left B on the right. My car is 05 axx and has a rev B. Doubt you will have a rev A cam. I think the BWA has a rev B but not 100% sure.
« Reply #9 on: July 08, 2015, 10:04:40 pm »
if I remember correctly the axx and bwa engines have slightly different compression ratios...
Offline doylebros
Offline Ricky123
  • -Receive: 27
« Reply #11 on: July 08, 2015, 10:22:48 pm »
Cheers I'll check cams on Friday and let you no.
56 mk5 ed30 3dr
Offline Ricky123
  • -Receive: 27
« Reply #12 on: July 08, 2015, 10:23:53 pm »
Don't think compression ratio will matter as its not massively different?
56 mk5 ed30 3dr
