Author Topic: RCD510 Bluetooth Activation  (Read 6834 times)
Offline fletch-
« on: July 09, 2015, 06:45:44 pm »
Hi guys, recently brought my golf gt tdi and was disappointed with a lack of aux! So I brought a RCD510 DAB. All is working fine and I love how much better the sound is!! However, it has a Bluetooth button, how do I and what do I need to buy for this to work? Many thanks
Offline robmcclel
Re: RCD510 Bluetooth Activation
« Reply #1 on: July 10, 2015, 10:44:42 am »
You'll need a Bluetooth interface module, something like this
http://www.ebay.co.uk/itm/OEM-Bluetooth-Interface-Module-9W2-FOR-VW-Volkswagen-RCD510-1K8-035-730-D-/310782526885?pt=LH_DefaultDomain_3&hash=item485c1505a5
That might not be the exact one you need cause I'm no expert but it says it is compatible with the rcd510
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #2 on: July 10, 2015, 10:59:51 am »
I think that module is old now, hence the lower price. Look for a 7P6 module. I think there are some for sale in the For Sale section of this forum. :wink:
Offline fletch-
« Reply #3 on: July 10, 2015, 11:13:23 am »
Lovely thanks. Do these plug in to the harness then? And do they need coding to work?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #4 on: July 10, 2015, 11:35:49 am »
They have a loom that connect to the rear Quadlock connector, yes.
They need coding but it's easy. Mine worked fine before I coded it but had errors with VCDS that were solved after coding. :happy2:
Offline fletch-
« Reply #5 on: July 10, 2015, 12:04:46 pm »
Cool that's great. I'm new here, do I have to have a certain amount of posts before I can PM? I want to get in touch with Eddie-nl about a dab aerial and this Bluetooth module? Thanks!
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #6 on: July 10, 2015, 12:08:33 pm »
Yes, you need to have 10 posts, I think. Read the rules to get to know the forum. :wink:
Offline Blackgtiman
« Reply #7 on: July 10, 2015, 01:33:29 pm »
get a 7p6. it will need coding and you may need a canbus upgrade as well (as I found out) as the 7p6 may not be compatible with your old canbus.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #8 on: July 10, 2015, 01:44:01 pm »
A RCD-510 already required a newer CANBUS. :wink:
Even a 1K0 907 530 L is compatible with a 7P6 module. :smiley:
Offline fletch-
« Reply #9 on: July 10, 2015, 01:51:29 pm »
Lovely thanks a lot guys. Had vxr's for years and they were so simple conspired to my golf haha will take some getting used to
Offline robmcclel
« Reply #10 on: July 10, 2015, 01:56:20 pm »
Vxr's?
 :signLOL:
Offline fletch-
« Reply #11 on: July 10, 2015, 02:02:58 pm »
A corsa and Astra Vxr  :sad1:
Offline Blackgtiman
« Reply #12 on: July 10, 2015, 03:39:41 pm »
i have a late version K which has no battery drain so im using that but it does not allow coding of the 7p6.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #13 on: July 10, 2015, 03:59:09 pm »
K versions are only good enough for the battery drainage of RCD/RNS-510, not good enough for RNS-315 and newer BT modules. Get a newer CAN, L, Q, etc...
Offline fletch-
« Reply #14 on: July 10, 2015, 04:31:44 pm »
Mine is a late 58 plate built in 2009 so I should be ok with the canbus gateway shouldn't I? It's been in 4 days now and battery hasn't died so :D
