Author Topic: RCD510 Bluetooth Activation  (Read 6831 times)
Offline Blackgtiman
Re: RCD510 Bluetooth Activation
« Reply #15 on: July 10, 2015, 04:34:46 pm »
I planned to but its working fine with rcd510 and 7p6 for now. no drain. I can make calls not sure if Bluetooth music works as not tried it. just cant code it that's all.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #16 on: July 10, 2015, 04:40:03 pm »
Mine is a late 58 plate built in 2009 so I should be ok with the canbus gateway shouldn't I? It's been in 4 days now and battery hasn't died so :D
Yeah, you're fine. Your CAN should be a Q version like my GT Sport. :happy2:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #17 on: July 10, 2015, 04:41:16 pm »
Like I said, mine worked fine before getting it coded. The coding just made the VCDS error go away. :grin:
Offline fletch-
« Reply #18 on: July 10, 2015, 04:48:50 pm »
Lovely thanks for your help guys! :happy2:
Offline Jamie9004
« Reply #19 on: August 16, 2015, 11:32:20 am »
Reviving this thread if poss, I have a 08 golf edition 30, fitted rcd510 dab works fine, now fitted a 7p6 Bluetooth module which also works but no1 can hear me! I have now got vagcom which is saying I need to code it so coming up as a error , any1 done this or is there a tutorial in which I can't find! New to vagcom and don't want to make things worse haha
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #20 on: August 16, 2015, 01:08:43 pm »
Did you get the loom with the bluetooth module? The mic might need the wiring checked...
Offline Jamie9004
« Reply #21 on: August 16, 2015, 06:20:46 pm »
Yes pal I got the loom as well. Checked the wiring all ok. Bought another mic before I realised to plug it in vagcom. Tried the new one and still not working
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #22 on: August 16, 2015, 06:50:40 pm »
Check this picture to see if it helps you:
Not sure how your loom is making the connections.
Offline Jamie9004
« Reply #23 on: August 16, 2015, 09:44:02 pm »
May help, will crack on with that over next few days now am back at work. Many thanks for your help
Offline Lyons
  • -Given: 18
« Reply #24 on: August 16, 2015, 10:57:49 pm »
Fletch I have a 7p6 Bluetooth module for sale, could've posted it with the grills!
Offline fletch-
« Reply #25 on: August 20, 2015, 05:48:28 pm »
 :sad1: I didn't know mate!! Will be in touch then next payday as I'm still in need of one  :happy2:
